Upper hood lift support bolt replacement
Old Mar 23, 2026 | 07:35 PM
JohnnyO's Avatar
Default Upper hood lift support bolt replacement
First time post. Please relocate if appropriate. My 2005 has 147K on it and is showing wear. The upper mounting bolt for the hood lift assist cylinder (proper name?) rusted away to where the spring clip just fell off. Before I get inventive on a fix I would ask if anyone has run into this and has a good fix or parts source for the bolt. I spent a long time online searching to no avail. Just too specialized I guess. The support cylinder is fine, so is the lower mount.
Thanks in advance
FYI fixed:
sticky key
RCM
alarm module
TPS wire disconnect
Old Mar 23, 2026 | 09:25 PM
Default Re: Upper hood lift support bolt replacement
Thanks in advance
FYI fixed:
sticky key
RCM
alarm module
TPS wire disconnect
A picture would help. Then we can see what the actual problem is. Someone has probably fixed one before.
Old Mar 24, 2026 | 10:26 AM
NeedsWings's Avatar
they are discontinued but i just found one new old stock in europe, i can have it brought over but it would be $53 by the time it is shipped over seas. if you want to proceed let me know and i can get it ordered in.
Old Mar 24, 2026 | 12:12 PM
JohnnyO's Avatar
Thanks but that's a bit too pricy for a simple repair. If I were doing an all original resto -, I would consider it. Here are pics as requested. Having never posted before I reduced size and hopefully didn't screw it up.
Old Mar 24, 2026 | 12:55 PM
NeedsWings's Avatar
yes, i agree it is expensive, i am surprised i found one still available.
Old Mar 24, 2026 | 06:58 PM
I found this on ebay: Hood ball pin
It's part # 80 in the diagram.
Mercedes shows it as: Hood ball pin
Hopefully this is what you're looking for.
Old Mar 24, 2026 | 08:27 PM
JohnnyO's Avatar
Fixed, sort of.
Removed the bolt (M8x1.25) ground the end clean and flat, center punched, drilled #21 bit, tapped 10-32, and what the British would call a "bodge" told myself it should hold up for a few years. Ugly but it works. Thanks for all who chimed in with help.
Thanks to mod for moving to appropriate section.
Old Mar 25, 2026 | 11:16 PM
Fixed, sort of.
Nicw TEMP fix. A member posted one on fleabay for sale for less than 5 bucks for the part with 9 bucks shipping. If it was me, I would buy the OEM pin. Good luck with your fix!
Old Mar 26, 2026 | 03:08 PM
JohnnyO's Avatar
The ball end stud is easy to find but fits the lower end. the upper is different. Thanks for trying! Seems like I have a whole staff of parts researchers here.
dcskmail
Aug 14, 2023 10:36 PM
crossroadshd
Aug 31, 2018 01:18 PM
nickwe21
Apr 8, 2018 05:00 PM
wvwonder
Dec 19, 2014 03:35 AM
MyFire91
Mar 28, 2013 03:51 PM
