Side Light/Parking Light
Old May 13, 2007 | 06:59 PM
SteveB1's Avatar
Talking Side Light/Parking Light
How the hell do you change this bulb...i cannot even get my hand in to that small space it's crazy...any help welcome.
Old May 13, 2007 | 10:26 PM
CrossfireLTD's Avatar
Cool Re: Side Light/Parking Light
You have to find someone with very small hands, or remove the headlamp unit which is not an easy job.
Old May 16, 2007 | 08:01 AM
Steve Hellums's Avatar
Default Re: Side Light/Parking Light
If you are talking about the side marker light in the front fender, just get hold of the lens toward the back of the fender and push it forward and the whole lens pops out.
Old May 16, 2007 | 02:09 PM
HDDP's Avatar
The side markers are easy... the entire housing pops-out of the body panel then pops back in... push it out from the backside...
Old May 18, 2007 | 04:48 PM
@lekk-man's Avatar
I think he is talking about the W5W lamps !
It took me about half an hour to change both last time I changed them ! I didn't find anybody with small hands, and mines are pretty big... So I had to find a way to do it !
I've used different tools but i can't remember the english names.. Just classic tools kind of like those: http://perso.orange.fr/yannick.fetre...ges/pinces.jpg ...
Old May 18, 2007 | 04:58 PM
SteveB1's Avatar
Talking Re: Side Light/Parking Light
Yes your right its the W5W bulbs what a place to put them. I can see where your coming from with those tools i have most of them i will give them a try...fingers crossed.
Old Jun 21, 2007 | 02:04 AM
blacklimitedcoupe's Avatar
I think it is possible to access them from the fender well if you drop the liner...
Old Oct 14, 2007 | 07:02 AM
popojoe's Avatar
I just changed mine out and replaced them with red led bulbs. The easiest way I found was to take a flat head screwdriver and place it on the edge of the bulb hold. Then gently tap it until it rotates vertically. Then you just slide it out, replaced the bulb, and put it back in. Once in place, reverse the procedure, lightly tapping it until it rotates back horizontally.
Old Oct 30, 2007 | 08:59 AM
SureDid04's Avatar
popojoe is right. i replaced mine and that's exactly how i did it. took about 45 minutes but the orange LEDs look great.
Old Jan 9, 2008 | 09:44 AM
MrQue05's Avatar
Is this the same procedure for the ones in the rear?
Old Jan 9, 2008 | 09:57 AM
Yeah, only in reverse. If I remember correctly, get hold of the end toward the front of the car and push it toward the rear. They are not as easy to pop out as the front one's are.
Old Jan 10, 2008 | 06:32 AM
MrQue05's Avatar
I used a credit card and it pooped out with no problems...
If I change one should I changethe other or just wait for it to go out as well? The replacement light comes in a set of two.
Old Jan 10, 2008 | 06:48 AM
I'd just wait till the other one went out, if they come in pair's you'll have one ready when it does. I done some modification to the hole the len's fits in and used some inverted cone red LED's. The clear marker lights was a tight fit, you can see a few little marks I made on the edge of the hole trying to get the clear marker light back out to remove a red dot sticker off the bulb, the marks arn't that noticeable except in a close up pic.
Here's a new lighting mod - Pic's inside-p1010698.jpgHere's a new lighting mod - Pic's inside-p1010701.jpg
Old Oct 19, 2012 | 05:26 PM
sodden_skier's Avatar
I just changed done of the these the other day, filmed it, and uploaded to YouTube. Check it out if you're having problems.
Old Oct 19, 2012 | 06:21 PM
Parking light removal.
https://www.crossfireforum.org/forum...tml#post615377
Hoppy
Dec 7, 2018 07:36 AM
PimpDaddy
Sep 29, 2016 11:55 PM
waldig
Sep 2, 2015 11:02 AM
ricardo 53
Jul 21, 2015 07:49 AM
waldig
Jul 20, 2015 08:10 AM
