How to program your own key. SAVE $$$
Old Oct 6, 2014 | 02:51 PM
  #121 (permalink)
eagle670's Avatar
Default Re: How to program your own key. SAVE $$$
Does anyone know if you can just by the key without the remote control?
Old Oct 6, 2014 | 02:54 PM
  #122 (permalink)
There is more to it than just the key.
There is a transponder chip within the housing that tells the SKREEM module that you have inserted the correct key.
Without that chip, the engine will not start.
This is apart and separate from the remote lock/unlock and panic functions in the key fob.
Old Oct 6, 2014 | 02:56 PM
  #123 (permalink)
eagle670's Avatar
Can you buy just the key with the chip without the FOB?
Old Oct 6, 2014 | 03:41 PM
  #124 (permalink)
no sir, you cannot.
( At least to my knowledge, If anyone knows different, correct me. )
The Chinese fob cases are pretty cheap anyway.
Old Oct 7, 2014 | 02:10 PM
  #125 (permalink)
eagle670's Avatar
I am getting a remote start put on the car and I have been asked the question as to if the transponder is pre-programmed when you order the key and if the transmitter for the locks are what you program yourself.
Old Oct 8, 2014 | 11:07 AM
  #126 (permalink)
eagle670's Avatar
In case anyone is wondering. When you order your key it is preprogrammed to start the car. The locks are what you have to do yourself. They said it takes about 30 seconds to program.
Old Dec 16, 2014 | 12:34 PM
  #127 (permalink)
RedRover's Avatar
New key from Mercedes/Texas would not program by inserting key, then pressing LOCK twice , then turning to ON. Tried five times. Reversed sequence to pressing LOCK twice , Then inserting key and turning to ON and it worked first time. Just an F Y I .
Old Dec 16, 2014 | 01:19 PM
  #128 (permalink)
Mrmiata's Avatar
Where are people getting this "insert key" first? All I've read till lately states press twice.. within 30 seconds insert and turn to on position. Girl on Facebook claimed I posted insert key.. hold button for 30 seconds then turn on.. umm..don't think so. Needless to say she never produced a link to that statement. Ironically it worked for her though.. LOL
OH hell.. never mind.. pulled up post #1 .. LOL..
Old Dec 16, 2014 | 01:27 PM
  #129 (permalink)
syfi's Avatar
That exact same statement (from post #1) is sent with every new key purchased through Needswings!
I tried the same procedure as the manual stated and had no success. Pulled the key out and did the button push before inserting and worked like a charm. One thing I'm wondering about is how long these replacement keys have been laying around. Mine would only work close to the car and if it was pointed only one way and not the other. 3 weeks later and she died completely. Fresh batteries and she's working normally like she should have, from 5 times the distance and pointed either way. If these keys were produced during the cars mfg. and still hold the original batteries, the batteries would be reaching their 7 yr limit just sitting on the shelf!
Old Dec 16, 2014 | 01:29 PM
  #130 (permalink)
Mrmiata's Avatar
Originally Posted by syfi
That exact same statement is sent with every new key purchased through Needswings!
Guess I should have looked for paper work when the wife's key came in.. but it worked right out of the box.. no sync. needed.
Old Dec 16, 2014 | 01:37 PM
  #131 (permalink)
RedRover's Avatar
Mrmiata.........key programming info from Crossfire forum site - ShawnKey
Old Dec 16, 2014 | 01:45 PM
  #132 (permalink)
syfi's Avatar
Mine probably would of too. I think the low battery had something to do with mine not syncing out of the box.
Old Dec 16, 2014 | 01:54 PM
  #133 (permalink)
To synchronize the key fob transmitter
This may be required after replacing the batteries or when receiving a replacement fob.
Directions as stated in the Owner Manual.
1, Aim the transmitters red eye at the vehicle.
2, Briefly press the lock or unlock button twice.
3, Within 30 seconds, insert the key in the ignition.
4, Turn the key to the ON/Run position.
The remote control function should again be operational.
Available as a PDF.
Old Dec 16, 2014 | 10:54 PM
  #134 (permalink)
Mrmiata's Avatar
Available as a PDF.
Old Jan 13, 2015 | 12:10 PM
  #135 (permalink)
coo.sandy's Avatar
hi there I dropped my key in water and after I tried doing the sinc process without any success the red lazer light of the key does comes on can anyone assist me pl. Eddie
Old Jan 13, 2015 | 12:13 PM
  #136 (permalink)
coo.sandy's Avatar
hi there I dropped my key in water and after drying out the key and motherboard and replacing the batteries I tried the sinc test without any success there is a red lazer light visible on the key can anyone help pl. thanks Eddie
Old Jan 13, 2015 | 01:38 PM
  #137 (permalink)
The red light is just that - a red LED that only serves to indicate that a button has been pushed and the battery is OK.
There is NO InfraRed (IR ) interface to the car, it is all Radio Frequency ( RF ).
The key should still work to start the car, as this is done by an RFID chip in the fob ( not on the circuit board ) that should not be water sensitive.
That part about "aim the transmitters red eye at the vehicle" is pure BS.
Old Jan 13, 2015 | 05:07 PM
  #138 (permalink)
coo.sandy's Avatar
hi thank you for the responce I think I am a bit blond anyway the car is completly dead the car battery is 5mnths old do you think I should disconnect the battery of the car and repeat the procudure also should I wait for the 30 sec to past before turning the ignition on and also should the red light of the key (go on) be visible because if I press the button momentarily twice the red light does not go on is this normal Help!!! pl. EDDIE
Old Jan 14, 2015 | 11:20 AM
  #139 (permalink)
I guess you took the fob apart to dry the PC board.
If so maybe you lost the little chip in front of the PC board. If you did the car will not start.
See the tenth post in this thread (click) to see the chip I am speaking about.
Old Mar 29, 2015 | 02:47 PM
  #140 (permalink)
Gregga's Avatar
crossfire keys are very hard to come by here in the UK
would the same work with a Merc SLK320 key??
