Transmission Leak - O Ring Part Number
Can anyone tell me the part number for the O ring that needs to be replaced for the dreaded trans leak ? If you took yours in to the dealer check your paper work, It might have the part number on it. I want to be sure I get the right part before I start any work on it.
Thanks...Roy
Thanks...Roy
Originally Posted by eruby
ditto. must be because i have it too.
Difficult thing is not replacing the parts (O rings, etc.) It is my understanding that filling the transmission with the correct amount of fluid is not as easy as it sounds. There is no dip stick to check it. It is temperature sensitive. You may want to check this out. Use the search I remember reading a thread where someone use/made a home made device to use as a dip stick in the fill tube.
Crossfireconv08
Jul 30, 2015 12:11 PM
SuperD500
Jul 23, 2015 02:53 PM
