Problem with wax
Old Mar 17, 2008 | 07:16 AM
Sinners's Avatar
Default Problem with wax
So it is a long story exactly how this happened, but my entire engine compartment had wax applied and was never buffed off. It has now been there for several months. I need a solution. It is on all the black plastic and I just cant stand it any longer. And all of this back to black crap doesn't work worth a damm. Any ideas?
Old Mar 17, 2008 | 07:22 AM
RPM's Avatar
RPM
Moderator
Default Re: Problem with wax
Might want to try some 3M Adhesive Remover or some Wurth Clean Solve:
http://www.autogeek.net/wuclso32ozca.html
Old Mar 17, 2008 | 08:02 AM
StealthESW's Avatar
I would try some Dawn dishwashing liquid diluted in some water. You should be able to use a brush on just the black parts. Something with soft bristles and the soapy water might get it off.
JMHO
Old Mar 17, 2008 | 11:19 AM
sonoronos's Avatar
Any ideas?
PPG wax and grease remover (available at the auto parts store)
Kerosene, JP4, and even Gasoline will work.
Soapy water will not work (unfortunately), although some people have mentioned (creamy) peanut butter as a wax remover.
I myself prefer aliphatic solvents because they don't leave a residue.
Old Mar 20, 2008 | 06:01 PM
patpur's Avatar
Senior Member/Moderator
According to some of the wax/polish manufacturers Dawn does remove wax/polish. The problem with your issue is its probably baked on. You can try the Dawn but you might have to go with a solvent to get it off.
Wonder why someone put wax on and didn't take it off? Have you tried 3M Plastic cleaner on the plastic? Good stuff but it might be a bit late for that.
Pat
Old Mar 21, 2008 | 12:30 AM
manisusmc's Avatar
windex or wd-40
Old Mar 21, 2008 | 01:53 PM
Xfire fan's Avatar
Originally Posted by manisusmc
windex or wd-40
+1 with manisusmc WD-40 will probably do the trick.
Old Mar 28, 2008 | 01:35 PM
randyveach's Avatar
Good question. I'm sure you're going to try a few of them. I would be interested in what worked, and what didn't.
Old Mar 28, 2008 | 01:57 PM
I keep three "solutions" in a special breifcase that work everytime on any problem.
Solution one= WD-40
Solution two = Duct tape
Solution three = A single malt scotch.
WD cleans just about anything, Duct tape fixes just about anything and if they don't solve the problem, then pour the scotch.
Go with the WD and give it some time, like 30 minutes or more. Have 2 fingers of booze while your waiting and then scrub off the wax with soapy water (Dawn does work best)
Repeat process until it doesn't matter.
Roadster with a stick
Old Mar 28, 2008 | 02:37 PM
Steve - UK's Avatar
Cool Re: Problem with wax
DONT USE SOLVENTS it will ruin your paintwork and plastics - the best, quickest, cleanest, most thorough solution - which not damage anything - is to take the car to the garage and have it steam cleaned (not just high pressure cold water which wont touch it) The steam melts the wax away and will completly clean everything.
Old Mar 28, 2008 | 04:18 PM
patpur's Avatar
Good idea Steve, never thought of steam. By the way which Gibson's? I had a 69 Les Paul Standard and a 57 dbl cutaway LP Junior. I wish I still had them!
Pat
Old Mar 28, 2008 | 05:33 PM
Jeep2Xfire's Avatar
Before doing this, get some dielectric grease in all wiring harness connections to insulate them from the condensation that is about to build up with steam/watervapor/water about to build up. Not too many weatherpack connectors in there, if any. Life would suck to have to replace a 200$ sensor by spraying it down without the proper protection.
A great time to reset the adaptive strategy while you're at it
franklindm
Mar 14, 2020 12:23 PM
eikon
Sep 9, 2019 10:16 PM
jimf
Oct 10, 2015 10:22 AM
Abaton6
Sep 24, 2015 10:14 PM
Den656
Sep 23, 2015 12:27 PM
