Outside Temp adjustment
Old Sep 28, 2008 | 06:46 AM
Default Re: Outside Temp adjustment
some people need something else to do, I don't even pay attn to mine...I'm too busy having fun and listening to the sc whine...I whine enough about other things...
Old Sep 29, 2008 | 10:41 AM
Nightrider's Avatar
Try stickng it in a body orifice and see if you get 98 or 99 degreees.
Old Sep 6, 2009 | 06:25 PM
Waldig!
That "resistor" your replacing is NOT a RESISTOR! It is called a THERMISTOR. It is a temperature variable resistor, when the temperature goes up, the resistance across its wires decrease. When the temperature goes down, the resistance increases. In no way will a fixed resistor work in this application. Your insertion of a fixed resistor in the IAT sensor is to "fool" the computer into adjusting the fuel/air ratio making it burn more gas for the air entering the intake. This does increase a little, the power you have available since it is running rich all the time. This also costs more in fuel used, but you don't care if your goal is more power.
I digress, the temperature sensor is a THERMISTOR, its function is to just display a value digitally, given its range and application. Its very word (thermistor) tells you it is a temperature sensing resistor. Its construction and function differs greatly from a fixed value resistor. If you install a fixed resistor in this application, your display will read almost a constant value across a wide temperature environment.
Old Sep 6, 2009 | 07:23 PM
Waldig!
Resistance goes down as the temperature decreases if I recall. At absolute zero there is no resistance.
Old Sep 6, 2009 | 09:24 PM
Your recall is correct IF you were referring to a CONDUCTOR. A semiconductor such as this thermistor has different properties
Old Sep 6, 2009 | 09:31 PM
green-ghost's Avatar
"It was a one in a million shot doc"
Old Sep 10, 2009 | 04:53 PM
Well at least I was half right, that's better than being half wrong.
Old Sep 10, 2009 | 05:36 PM
waldig's Avatar
Talking Re: Outside Temp adjustment
You buffer the thermistor with a resistor to add to or reduce its setting at a given temperature. It will still only be right at a given narrow range after buffering, its a cheap part and not precision, Woody
Old Oct 22, 2009 | 03:49 PM
Goldwing's Avatar
My A6 has a disclaimer in the user manual that the temperature reading can be a few degrees high when the motor is running just due to engine temperature. BTW, in a roadster you have a pretty good idea of the temperature all the time if you drive with the top dropped.
Nov 11, 2015 05:22 AM
2005 Ragtop
Oct 3, 2015 03:01 PM
amx1397
Oct 2, 2015 05:20 PM
Oct 1, 2015 01:42 AM
grip grip
Other Cars Etc
19
Sep 19, 2015 08:43 PM
