Plug removal
Old Jan 9, 2009 | 08:26 AM
little wing's Avatar
Default Plug removal
Can anyone recommend a suitable tool/socket to get the plugs out.
Can't even see where they are, & it don't look easy..........
Is a multi-jointed socket, or plain straight socket of the right length???
What do i need????
Old Jan 9, 2009 | 08:38 AM
waldig's Avatar
Talking Re: Plug removal
Look up my posting:How to change your 6 spark plugs easily on July 14 2008 for the information, Woody
Old Jan 9, 2009 | 09:10 AM
Stogey's Avatar
Default Re: Plug removal
Woody ! 6 plugs ??? LOL
Old Jan 9, 2009 | 10:11 AM
spensley's Avatar
12 plugs, 2 per cylinder.
There is a MB tool - it does help - basically a spark plug wrench with a universal joint on the end.
There's a couple of write-ups on the forum - they do help - I have attached one (gloves optional).
Small hands REALLY help.
FYI, the plugs are supposedly good for about 100/120 thousand miles
File Type: doc
Old Jan 9, 2009 | 10:23 AM
mrphotoman's Avatar
you can get the same generic tool at any parts store for $5.00
Old Mar 17, 2013 | 12:14 AM
chilleary's Avatar
I used the 18mm open ended wrench to get the plug wires off (Thanks!, great tip). Had to use a small cresent wrench for the last plugs on both sides closest to the firewall (my 18mm was too long). Used a hammer to tap the cresent wrench once I had it on the plug wire end.
Using anti-seize was a great idea too. Couldn't quite determine how hard to torque but nothing stripped (I don't think).
One thing I did was when I put the plug wires back onto the spark plugs I started with the plug nearest the firewall and worked forward, that kept everything out of the way so I could work with the 18mm to pop them back on.
Changing the 12 plugs took me 3 freakin' hours! Those Germans need to figure out a way to allow basic maintenance in less time, this was rediculous. But thanks for all the tips, they worked great!
Old Mar 17, 2013 | 09:04 AM
Welcome aboard.....lol... I guess that 4 year old post was a good help for you.... Always check the dates....but the info is still correct... some info may not be as we keep learning more and more about these little cars....
4drturbo
21
Nov 12, 2018 04:50 PM
smokey847
Nov 12, 2015 11:54 PM
RacerXofFL
Sep 15, 2015 05:00 PM
55chevy
Sep 13, 2015 07:38 PM
jaesa
Sep 7, 2015 01:50 PM
