Rear Window Fix
Old Dec 8, 2010 | 10:44 AM
GeorgeC1031's Avatar
Default Re: Rear Window Fix
Has anyone experienced problems with the rear window defroster after reattaching the rear window? I noticed mine is only partially working now after using gorilla glue for the rear window fix. The rear window is holding fine from August with no leaks or separation but the rear window defroster is now only partially working. Any Suggestions?
Old Dec 13, 2010 | 10:38 AM
magneticred's Avatar
Check for breaks in the heater element.
Old Dec 13, 2010 | 01:43 PM
XFireCrazy's Avatar
I am glad you posted this.....cuz, now that I think about it....I did not reattach the contact wire for my rear window defroster. lol I better go do that before we get a freeze here.
Old Dec 20, 2010 | 03:31 PM
martylogs's Avatar
Yes, get the new top while they will. I've been in the auto biz for 30 years and I know a good deal when I see one. As stated, you fix anytime in the future with a newer top. Sometimes good looks is not the real condition of the fabric. Go new, they will not offer again.
Old May 10, 2011 | 08:18 PM
chaotictaco's Avatar
WTF!!! 250 bucks my dealer told me 1600 bucks for a new top!!
Originally Posted by XFireCrazy
I bought the 3M Window Weld and I am gonna go give it a try right now (if I can avoid playing online poker instead). I live in Dallas and the rear window of my 05' roadster starting to come off about a month ago. It is only about 1/4 of the way peeled off on the drivers side from what I can tell.
My dealer said that they could replace the entire top for $250, but I figure I will give this a try first. If it does not hold, then I can have them replace it later.
It is currently 65 degrees here in Dallas, so hopefully that is not too cold for this repair.
Old May 10, 2011 | 08:23 PM
ok so im seeing i'm not the only one who has lost there back window. I have an 05 crossfire roadster, but my back window came out all the way, top, sides and bottom. AM i SOL on fixing it now, cuz i dont have 1600 bucks to get a new top. I just used epoxy and some cheap plastic from a jeep window to cover the hole for now. But it still leaks so yeah please help me
Old May 11, 2011 | 08:01 AM
The Gorilla Glue I used last summer to reattach the window is still holding fine. I have had the roof down several times and no problems so far other than the clip for the rear window defroster came off. i recently reattached the clip with a kit I bought on-line. I can't test the connection at this time but the clip adherred to the window.
Old May 11, 2011 | 10:38 AM
dtinker's Avatar
What a deal, do the new top. That offer will go away real soon. Everyone I've seen just for the parts is $1200 up, installed about $1800.
Old May 13, 2011 | 07:34 PM
cisa's Avatar
Exclamation Re: Rear Window Fix
Had to redo it after 1 year. But, it still beats the $1,500 the dealer wanted to replace the entire top. However, for $250 get a new top!
Old May 13, 2011 | 07:54 PM
tighed1's Avatar
Just found another spot that is getting loose. Hope the stuff is still usable after all of this time.
Now where did I put it?
BTW - All of the original fix is still holding tight!
Old Jun 6, 2011 | 12:02 AM
TerryR's Avatar
Go for it, mine is still holding fine! They wanted $1,500 for a new top in south Florida. My $10 and some of my time was a GREAT investment for me. It will hold. Mine was only hanging from the top. Both sides and the bottom were undone.
Mine too, hoping to repair on my return from vacation in Britain. Most suppliers of our convertable tops require you to remove your complete existing top and send to them (excluding window) for them to fit new canvas and New Glass window. Has anyone removed the complete top. ???? I have recently come across someone selling a New Top which would then have to be fitted to the frame, but also don't know how easy/hard this would be to do.?? with being on vacation can't even investigate yet.
Old Jun 16, 2011 | 04:53 AM
TerryR's Avatar
I STILL have not had a response from any Forum member, to say they have had the experience of removing and/or replacing the Convertable top.
Easy/Hard ???? Surely someone has done it, and can advise me. I am prepared to replace my top, but don't know how involved it will get. Suppliers for NEW tops give a lifetime guarantee on the rear window adhesion, but removing the top in order to ship frame (less window).
Now returned from vacation, I will investigate myself this weekend, but any assistance/advise would be appreciated.
Old Jun 17, 2011 | 11:40 AM
tighed1's Avatar
Looks like you may be the first!
Take plenty of pictures!
Old Jun 17, 2011 | 01:56 PM
Kane's Avatar
Banned
Terry, you'll find a more extensive discussion and possibly a SOLUTION to the problem in the roadster sub-forum sticky .-. "Roadster Window Problem Solved?".
Good luck. I'm in the middle of the procedure myself and will advise of success, if any.
Mods, you may want to delete this inconclusive thread, or redirect to the sticky.
Old Jul 11, 2011 | 04:55 AM
TerryR's Avatar
Come on Guys, STILL waiting for someone to respond to my request for information on the procedure for removing/refitting the convertable top.
Don't know how easy/hard this is going to be.??
Someone MUST have done this. I am on the verge of getting my top recovered in Burgundy(OR maybe Blue)??, which I think will be a great contrast to my Alabaster Roadster. Waiting for canvas samples.
Hoping to start the removal process next weekend.
Old Jul 11, 2011 | 06:46 AM
Kane's Avatar
Banned
To my knowledge, there is only one manufacturer doing Crossfire tops (link provided above) and they require that the original top be sent to them so that they can fit it into the OEM head and rails. And if you look at the existing rail details, this makes sense. I doubt seriously that you will find a replacement top that is provided simply as a piece of canvas.
If you know this to be inaccurate, tell us more.
Old Jul 11, 2011 | 12:51 PM
TerryR's Avatar
I have been in Contact with 3 National Companies, who have responded with offers. "Cabrio World", "Convertible Top Guys" & "Tops on Line". All have given me various prices, and a selection of Canvasses (Including a Color selection, if required) and all tell me, they do not use the pocket system now, due to "New Glass Bonding Technology". But as you say, All require you to remove the Top, complete with Frame, but with window removed, and send it complete, to them, which was my intention. The window removal is presumably, as the window is subject to being broken, and as a new one is to be fitted, no need. All my offers include a "Lifetime Warranty".
I guessed some Forum Member has done this before. I don't know how involved disconnection/reconnection of the hydraulics & Electrics would be, it MAY just be straightforward, but unlikely on these cars. I will no doubt, find out this weekend whan I come to remove it. I will keep all informed, as to my progress, with pictures where necessary.
Old Jul 11, 2011 | 01:05 PM
  #38 (permalink)
dtinker's Avatar
TerryR;
I could come help on Sat. morning, but you would have to come pick me up. Somehow, I had it in my head that there are two connection points on each side, but the big thing is to disconect the sensor /electrical points, probably a harness or plug. I don't think the hydralics have to come off as I think the part that does that stays with the car. I'll go look at mine to see if I can see anything.
Old Jul 11, 2011 | 01:10 PM
  #39 (permalink)
TerryR's Avatar
Originally Posted by dtinker
TerryR;
I would appreciate that Dave. I could pick you up about 9.00am again if that is O.K. with you.
Old Jul 11, 2011 | 01:26 PM
  #40 (permalink)
dtinker's Avatar
9 am would be fine.
I looked at my car, looks like two screw mount connections on each side, one large ram on drivers side and one small ram on each side. you may be able to disconnect the rams and leave attached to the car and disconnect just the top mechanicals. Not sure until we start taking it apart. Looks like someone in the forum would have done this before. A little guideance would go a long way toward success.
I went and looked again, there is another ram on the driver's side that goes toward the rear and bottom of trunk floor. looks like it controls the cables that go to the little flap(wings) that come down with the cover. may be able to disconnect and not remove from car. Looks like the sensors just plug in with a connector.
