Hood liner sagging ... need suggestions
Old May 3, 2011 | 02:49 PM
IBLUBYU's Avatar
Default Hood liner sagging ... need suggestions
I've tried searching to see if anyone has come up with a way to stop the sag. My hood liner is sagging on my N/A just about over the Chrysler wing on the engine cover. It has coused some of the finish of the engine cover to rub off. I read where 180 cut a slit in the liner and tried double-stick tape to no success. Another member cut out a square in the liner. Don't really want to do that. I don't mind putting a slit in the liner, but I'd like to retain as much of the original look as possible. Anyone had success doing something to correct this?
BTW: removing the liner is a last resort .......
Old May 3, 2011 | 05:43 PM
SparkieSRT6's Avatar
SSB SRT6 405hp/401Tq
Default Re: Hood liner sagging ... need suggestions
Just an idea :
I would try using a medical syringe and draw some adhesive into it. Poke it through the sagging area and then squeeze the syringe so that the adhesive is sprayed or applied to the underside of the hood. Remove the syringe and then press the hood liner up against the hood and support in place.
I would think there are several adhesives that could work.
Old May 3, 2011 | 05:46 PM
bluecoupe's Avatar
Syringe huh? You been hanging out in Beaner's neighbourhood?
Old May 3, 2011 | 06:02 PM
IBLUBYU's Avatar
Just an idea :
yeah ... I thought of something like this .... pharmacies have oral dose syringes that they give to patients for dosing liquids to pets and children. I've never worked with RTV sealant, or that black stuff they sell for attaching rubber moldings, but is something like that thin enuff to flow thru a "syringe" thingy? Probably dont need a lot. Thanx Sparkie
Old May 3, 2011 | 07:02 PM
Larry Hitze's Avatar
What the heck just remove it. Mine never had one when I bought it and I've never missed it.
Old May 3, 2011 | 07:23 PM
green-ghost's Avatar
dont bother with a syringe, get a can of 3m adheasive, pop a few of the round tacks holding it on, spray and press, then put tacks back. On another note I had recently pulled mine off and thought it would look ghetto but it was really sweet loking without it.\
Old May 3, 2011 | 07:46 PM
texas t's Avatar
Smile Re: Hood liner sagging ... need suggestions
  1. i removed mine some time ago! Then removed hood and sprayed the underside with flat black heat paint .I like the look and easy to maintain
Old May 3, 2011 | 11:22 PM
blackcrossfire07's Avatar
You can't stop the headliner... It will eventually fall down. Get it redone. Cost me 140 and it took the professional a few hours. Actually it was 120 but I threw the guy a 20 dollar tip because he did it without messing up my interior.
Old May 4, 2011 | 05:26 AM
Or try one of these, theyre on ebay for 79 bucks which is a good price.
Old May 4, 2011 | 08:53 AM
He said hood liner not headliner.
I tried the slit and double sided tape and it did not work at all well.
Sparkies idea is good I think, use contact cement, let it get tacky and press it down.
velociabstract
15
Sep 7, 2015 03:43 PM
Bayukbros
Aug 28, 2015 08:59 AM
2ndtonone
Aug 24, 2015 09:18 PM
Boresite
Aug 9, 2015 10:33 AM
Jul 29, 2015 06:13 PM
