Question on front bumper removal
Old Jun 21, 2012 | 10:16 PM
nick78ru's Avatar
Question Question on front bumper removal
Hey guys,
I am in the process of removing my front bumper (got curb damage) and can't figure out how to remove the 4 screws (2 on each side) that tie the bumper with the front fender. I believe those are the only ones left...
Is there a way to access them easily? Service manual skips this step and refers to "removing the fender" page where it just says to get those screws out.
Does anybody have a how to with pics? I know the theory behind the process but actual pics are the best
Also, should I remove the front wheels to get the bumper off?
Thank you!!!
Old Jun 22, 2012 | 07:08 AM
Default Re: Question on front bumper removal
Removing the front wheels will make it much easier, then remove the forward inner fenders. The bolts will be in plain sight then.
James
Old Jun 22, 2012 | 08:32 AM
caddymike85's Avatar
James is right, removing the front wheels makes it a ton easier. Doing that will allow you to remove two screws from the wheel well lining and gain access to those screws. I find that it is easiest to use the 10 mm socket with an extension. Get the screw nearest the door by going through the wheel well and get the nut closest to the front by removing the turn signal light and passing your ratchet through the opening. Don't forget to unscrew the foglights too, its a lot easier then disconnecting the harness.
Old Jun 22, 2012 | 01:00 PM
nick78ru's Avatar
Thank you guys!
Old Dec 5, 2018 | 04:14 AM
kamilspider's Avatar
I looking for very detailed front bumper diagram. Who can help?
Old Dec 5, 2018 | 09:39 AM
The parts manual?
Old Dec 5, 2018 | 10:59 AM
Yes and also removable turtorial will be nice.
Edit 16/01/2019
After bumper removal I can say that is easy work. Our cars are well built.
maxcichon
May 14, 2019 07:30 PM
tom2112
Jul 28, 2015 08:12 AM
Jerrysrt6
Jul 24, 2015 09:15 PM
rmcdaniel12
Jul 21, 2015 11:35 PM
axnguyen
Jul 21, 2015 11:41 AM
