80,000 miles '06 6 speed crossfire
Old Sep 8, 2012 | 08:31 PM
C-mac's Avatar
Default 80,000 miles '06 6 speed crossfire
What do I need for an 80,00 mile tune up on an 06 6 speed crossfire. And is difficult to change transmission fluids in. What all is need for that
Old Sep 8, 2012 | 08:38 PM
Chris L.'s Avatar
Default Re: 80,000 miles 06 6 speed crossfire
I'm the original owner of an 07 6spd Limited with 82,000 miles. I bought the plugs, GO-5 antifreeze & Pentosin brake fluid .......next week gonna have a local garage do those things. Manual implies nothing needs to be done to the transmission.......
Old Sep 8, 2012 | 08:42 PM
C-mac's Avatar
The dealer ship wants to do the diff fluid
Old Sep 8, 2012 | 10:04 PM
Find a local shop you trust and get stuff done. That's what I do. Local shop has three brothers running it, one has a wife with an SLK 320 (our car's chassis and drive train) and he does most of my work. THis is the way to go, PLEASE, we have all read story after story here of dealerships charging WAY too much and sometimes not even using the right fluids.
Find a shop that does Mercedes and you'll be fine.
ALSO: You will get better help here if you update your profile with where you live, as someone here may know a local shop to recommend.
Old Sep 9, 2012 | 10:34 AM
C-mac's Avatar
Default Re: 80,000 miles '06 6 speed crossfire
Thanks I'm new to this. Bit have only worked on American cars. This is my fiancé s car. Trying to save money. The maintence on it is outrageous The dealership said it needed some work. Thy wanted to charge 350$ to change diff fluid and 105$ to change the air filter. What other things can I do to save money on maitnace I see how to do alot of the things just have problems finding parts
Old Sep 9, 2012 | 10:41 AM
If she is going to keep the car for say another 20k miles, then I would look at changing fluids and such. There are specific fluids for the car. But if she isn't going to do that and car is running fine, fluid levels are normal, I would just drive it. At 100K plugs, and all fluids would certainly need replaced. But, a shop that does foreign, especially German cars, is where I would go for whatever you can't do yourself. Changing air filters, and oil is pretty straight forward. I would stay away from Chrysler dealerships unless you know who you are dealing with in the service dept.
Old Sep 9, 2012 | 11:17 PM
closer9's Avatar
I just did my diff oil. It was 30min and $20 taking my time. Did it on the garage floor. Super easy to do. Easier than than either diff in my lifted 79 K5. Air filters are about the same price and take a few minutes...
I'll be tackling the manual trans oil next. From what I've read it's a tight fit, so going to use a friend's lift. Is yours auto or manual? Most things on this car seem to be rather easy to fix/maintain, but then I've never taken a vehicle to anyone for repairs or maintenance.
Old Sep 10, 2012 | 05:16 PM
C-mac's Avatar
Default
Mine is a manuel. Yeah I had it in the air it's a tight fit. Don't forget about the one time use fill plug. What size but did you use to drop the did flui and what kind of fluid did you use. I seen where the drain and fill plug are. It would just make it alot easier if you new
Old Sep 10, 2012 | 06:50 PM
Indelibility's Avatar
I think I'm reading this correctly, but you don't drop the diff. Just jack the car up so it's level, unscrew the fill plug first, then unscrew the drain plug and let that nasty fluid out. I used Amsoil 75W-90 fluid a few thousand miles ago and all is well. Not sure about the one-time use plug though, I reused mine...
Old Sep 10, 2012 | 07:19 PM
C-mac's Avatar
Default
Thanks. I'm talking about if you want to drop the transmission fluid
Old Sep 15, 2012 | 10:53 AM
C-mac's Avatar
Does anyone know good mechanic shop in the Arlington fort worth area I can take my crossfire to have work some on it
Old Sep 15, 2012 | 12:24 PM
closer9's Avatar
I guess I haven't seen anything about a one time use plug. On the trans?
I didn't jack up the car for the diff. Didn't need to...
mhajek18
110
Sep 6, 2019 01:04 PM
rayth
Other Cars Etc
Jul 29, 2019 07:59 AM
MJPowers
Jun 8, 2015 02:34 AM
adamlevy
Jun 7, 2015 08:13 PM
BlkCrossfireAR
Jul 26, 2003 02:47 AM
