Removal of driver side marker light
Old Apr 30, 2013 | 08:36 PM
cg80's Avatar
Default Removal of driver side marker light
Sopuld I removel the wheel ?
Old Apr 30, 2013 | 10:10 PM
Default Re: Removal of driver side marker light
Everyone has different names for different lights. Are you referring to the amber lens assy in the side fender? Is so, it just prys out using some type of plastic tool/device.
Old Apr 30, 2013 | 11:10 PM
+fireamx's Avatar
Andrew used a credit card. (I think it was a Platinum card).
Old May 8, 2013 | 01:09 PM
AlG's Avatar
AlG
The instructions for removal are in the owners' manual.
Old May 8, 2013 | 01:41 PM
You are correct, again.
From page 214 of the 2004 Owners Manual
Front and Rear Sidemarker Lights
1. Push the front sidemarker assembly in and slide it
forward. Push the rear sidemarker assembly in and slide
rearward. The assembly will release from the fascia.
2. Twist the bulb socket counterclockwise and pull out.
Push the bulb into the socket, turn counterclockwise and
remove.
3. Replace the light, push in and twist clockwise.
4. Realign the two tabs and push the light in until it
engages into the lock.
Kodebuster
Nov 5, 2020 04:06 PM
66L72M21
Jul 15, 2015 04:23 PM
shawnwatson9493
Jul 9, 2015 11:47 PM
2005 Ragtop
Jul 9, 2015 03:16 PM
joethejeweler
Jul 7, 2015 08:58 PM
