automatic transmission fill tube for fluid
Old Jul 17, 2013 | 10:45 AM
fyrepower's Avatar
Default automatic transmission fill tube for fluid
OK guys I give up. I know our cars do not have transmission fluid dipsticks. But where is the fill tube located if I need to add transmission fluid after I change the transmission filter
Thanks
Old Jul 17, 2013 | 10:51 AM
Default Re: automatic transmission fill tube for fluid
Take the engine cover off and look at the rear of the engine near the throttle body.
It has a sealed cap on it, you can remove the seal as I wouldn't think any sort of factory warranty is still in effect.
Old Jul 17, 2013 | 12:47 PM
fyrepower's Avatar
thanks, that was my next step tonight was to try and remove the engine cover
Old Jul 18, 2013 | 08:37 AM
fyrepower's Avatar
I found it. thanks for your help. The tab was already removed so I was able to take the cap off by gently pulling on it.
syfi
Mar 28, 2026 04:14 PM
jimf
Oct 10, 2015 10:22 AM
Oct 1, 2015 01:42 AM
DaveMe
U.K.
Sep 29, 2015 08:09 AM
rfourt
Sep 25, 2015 01:38 PM
