Door lock won't turn!!
Old Aug 17, 2013 | 10:03 PM
FloridaCrossfire's Avatar
Default Door lock won't turn!!
The key wont turn the door lock do the batteries in the fob have anything to do with it if not why won't it turn?
Old Aug 17, 2013 | 10:33 PM
philosophico's Avatar
Default Re: Door lock won't turn!!
Ive wondered about mine also, my key only fits half way in the door lock. So im worried if the battery in the fob goes dead guess i wont be getting in the car, or if the car battery died.
Old Aug 17, 2013 | 10:37 PM
Well my key goes all the way in but won't turn at all and I don't want to break my fob!
Old Aug 20, 2013 | 03:13 PM
AlG's Avatar
AlG
Surprising, because half the time my fob doesn't link with the car and I have to use the key to open the door and it works just fine. You have really turn it because it's making the air pressure unlock the door. After using mine so much it's not tough at all.
Old Aug 20, 2013 | 08:44 PM
robby363's Avatar
The key fob has nothing to do with it. Try spraying some WD-40 or lock oil in it. Probably just froze up a bit from not being used.
Old Dec 31, 2013 | 09:30 AM
scomer88's Avatar
I am having a similiar issue, My key fob is dead and ive been using my key for awhile and last night i went to lock the door and the key wouldnt turnvery easily, i then could get it to turn but the key would just turn the lock but the door would not actually lock, and i could keeo turning the key if i used enough force. Could this be something with the central lock unit in the trunk or with the lock mechanism itself in the door. I cant lock my car right now and its pretty concerning. Thanks for any input
Old Jan 19, 2020 | 02:45 PM
klm42005's Avatar
I’ve been researching for days on this subject. My door lock won’t turn with the key...the fob works to unlock and lock but the key hole will not turn either direction. I tried WD40 but still won’t budge. The key works ignition and glove box just fine. Im not sure my next course of action. I only have one one key/fob at the moment so being too aggressive is out of question but will welcome all advice.
Old Jan 19, 2020 | 03:36 PM
JSK's Avatar
JSK
Do you know that it has worked in the past?
Old Jan 19, 2020 | 04:48 PM
klm42005's Avatar
I don’t . I just bought her on Jan 9th.. it’s the only thing that hasn’t worked.
Old Jan 19, 2020 | 05:29 PM
You can remove the whole door handle assembly easily and see what the problem is. Thread is right hand on drivers door and left hand on the passenger door.
Post on how it is done. CLICK
Old Jan 19, 2020 | 06:14 PM
klm42005's Avatar
Thank you so much. This helps a lot. Gives me a great starting point.
pioneer4x4
Mar 25, 2019 10:35 AM
xfClifford
Aug 3, 2015 11:03 PM
pioneer4x4
Jul 27, 2015 02:04 PM
66L72M21
Jul 15, 2015 04:23 PM
cx24724
Jul 12, 2015 11:57 AM
