Changing CPS
Old Sep 1, 2015 | 01:36 PM
Firebombbandit's Avatar
Default Changing CPS
Hi,
I'm having trouble getting the little screw loose. I've tried all the various size sockets star and 6 edged from 6-8 mm and 1/4 inche but none seem to fit.
I've got a 2004 3.2 manual coupe RHD.
Any advice would save me some hair!
Old Sep 1, 2015 | 02:23 PM
Default Re: Changing CPS
Originally Posted by Firebombbandit
Hi,
You want an E8 Torx socket.
Click
Old Sep 1, 2015 | 03:37 PM
Thanks for the link. I've tried that socket. I can feel defined edges of the screw but still the sockets aren't biting so I may have a worn screw. I'll take a picture tmw and post but if it is down to a worn screw and suggestions/ advice from others out there who have had any experience dealing with that scenario would be greatly appreciated.
Old Sep 1, 2015 | 03:42 PM
pioneer4x4's Avatar
You might need something like this in a close size. They work pretty good. (obviously these are too large)
Old Sep 1, 2015 | 03:48 PM
Thanks for the link as they say, I've learned something new, never seen a socket like that before!
Old Sep 1, 2015 | 03:50 PM
What is your problem with the CPS?
Maybe the connector is causing problems.
Old Sep 1, 2015 | 03:59 PM
Not sure to be honest! Looking through different posts I've had typical symptoms i.e. fires up on a cold start, but won't after a short journey so tried new battery first (had original, which is impressive for 04 plate and 92k miles) then re-soldered RCM now onto the CPS.
Old Sep 1, 2015 | 04:52 PM
Do you have any codes set?
Old Sep 3, 2015 | 05:56 PM
Eventually got the pesky little bugger out using a friends 8mm torx socket. I guess mine wasn't a good make! New CPS fitted and she fired up first time. Left her running for a couple minutes. Turned her off for a couple and went to fire her up again and... I hear a very pleasing noise of engine 😎
A big thank you to everyone that contributes to the site and for providing the solution to help me get my car back on the road 👍🏻
Old Sep 3, 2015 | 06:42 PM
It has happened here before that a socket was identified as being the wrong size to what it actually was.
Valk
Jun 22, 2025 09:15 PM
UNDER PSI
Nov 1, 2015 09:39 PM
jimf
Oct 10, 2015 10:22 AM
o55ie18
Oct 5, 2015 05:50 PM
skeet370
29
Sep 18, 2015 05:53 AM
