Gas full door spring broke
Old Mar 4, 2016 | 12:34 PM
croneca's Avatar
Default Gas full door spring broke
Has anyone removed thier
gas fill door from their crossfire? Mine is a 2005 roadster. Stopped for gas the other day, after filling the tank closed the fill door and it will not stay closed. I can lock the doors and the gas filler door will lock closed. Soon as unlock drivers door fill door opens slightly. The popper retracts and push it to pop up.
Old Mar 4, 2016 | 04:30 PM
Default Re: Gas full door spring broke
So it cannot be ajar too much. The tether that keeps the cap attached to the car can get in the way, if so spin the tether around so it does not interfere with the body work.
I'll add some pics of the door area for you of what you'll see if you have to take it apart.
You'll have to remove the trunk interior panels as shown, you do not have to remove the carpet over the gas tank, just the too side ones.
I think that the whole door assembly is undone inside the trunk and remove from the outside.
Be careful of the door lock motor as noted, it is delicate and no doubt expensive.
See the Service Manual for full details.
To get to it click on the red "Index of repairs .........." in my signature below and look for The Crossfire documentation item, it is the first one on the list.
Photos by fastfunfor2
Old Mar 8, 2016 | 12:13 PM
croneca's Avatar
Awesome, I crawled into the truck the other day and looked at the backside of the filler assembly, could not figure out how that thing was held in there. Figured there had to be bolts somewhere I could not see. Good point about protecting the paint finish and to be careful with filler door air lock motor.
Thanks again
Old Mar 8, 2016 | 01:09 PM
Thanks again
From the Service Manual.
FUEL FILL DOOR
REMOVAL
1. Open the fuel filler door (1).
2. Remove the two bolts (2).
3. Remove the fuel filler door.
The bolts are by the hinge.
Trouble is I cannot see them on my 2005.
Old Mar 11, 2016 | 08:28 AM
croneca's Avatar
I drove the crossfire to work this morning, at lunch I will attempt to remove the gas filler door and take a look at the broken spring which holds the door closed. Thanks for the info from the service manual.
Old Mar 11, 2016 | 09:39 AM
As I say in the post I cannot see the screws that are supposed to be there according to the manual. I think the screws are inside.
Old Mar 11, 2016 | 10:42 AM
croneca's Avatar
Lucky for us here in the great north west, we have a break in the weather today. I will run down and look for those two bolts (screws) to release the fill door.
Old Mar 11, 2016 | 12:14 PM
croneca's Avatar
It was an easy disassembly. Removed the filler door pneumatic locking actuator, locking pin and rubber over flow hose. Removed cap from tank, 4 clips held the assembly to the rear panel and it came right out.
Here are the 4 clips locations to get the assembly out of the fender, two on top and two on the bottom:
Here is a pic of the hinge, it has a key way formed in the center. The plastic key on the hinge pin broke.
Spring connected to the hinge pin. I ended up super glue the pin and fill door back together.
I am back up and running with a closed fill door again. Thanks for the help, have a great weekend
Old Mar 11, 2016 | 11:41 PM
.Spring connected to the hinge pin. I ended up super glue the pin and fill door back together.
I am not to sure about the super glue use here. It depends on the forces trying to tear the part of again. Pealing strength of these glues is not too good.
helosixx
Jan 17, 2016 10:22 AM
gbstonecat
Jan 5, 2016 02:21 PM
twboyle
Jan 1, 2016 03:03 PM
Bifftws
Dec 30, 2015 03:39 AM
Travish
Dec 20, 2015 09:53 PM
