Fog light interchange left to right
Old Feb 28, 2019 | 07:34 PM
Default Fog light interchange left to right
Our fog light is a left and right ,but moving the adjustment screw on a left hand from 5 o clock to 7 o clock position it makes it a right hand, take a look at the pictures,,, not talking about the light housing that mounts the fog light to the bumper.
Old Mar 1, 2019 | 01:08 PM
Default Re: Fog light interchange left to right
Im confused. If you are not talking about the HOUSING, then does this really get us anywhere? (I no longer have a limited so I have no fog lights to mess with.)
Old Mar 1, 2019 | 01:58 PM
Not the housing but the light (not blub) which is interchangable with either side ,,to be mounted into the housing. if you order a new fog light, you also have to order the housing ,,some times like with Rede Dog his chrome inside the fog light burned,,got wet, it is no longer a nice bright light so replacing the part of the fog light saves money. and it can go on either left or right.
Old Mar 2, 2019 | 04:25 PM
You
So for this fix you have to have a fog light that has a decent glass lens with a damaged reflector/bulb mount that needs replacing?
It has got to be a rare situation when you find yourself in Red Dogs situation, although it did happen to me when I came into possession of a fog light that had damage just to the bayonet fitting for the bulb. I purchased a fog light that just had the glass broken but had a good reflector, the seller was lucky to get some money for an otherwise useless part. Normally the reflector would only get damaged by contact with water.
I became aware of the interchangeability when I took apart my damaged fog light and compared the pieces to my spare set of fog lights.
White Thunder
Oct 28, 2017 01:38 PM
White Thunder
Oct 28, 2017 12:36 PM
CrossfireKat
Apr 13, 2011 06:04 PM
SillyMan
Mar 13, 2010 01:02 AM
scoutmstr
Apr 23, 2009 11:34 AM
