Center High Mount Stop Light
Old May 6, 2020 | 11:40 AM
angelomd's Avatar
Default Center High Mount Stop Light
Does anyone know how to remove the CHMSL from my 2005 Limited Convertible.
Old May 6, 2020 | 04:17 PM
Default Re: Center High Mount Stop Light
CENTER HIGH MOUNTED STOP LAMP
DESCRIPTION
The center high mounted stop lamp (CHMSL) uses LED’s for illumination, they cannot be adjusted or repaired. If
faulty or damaged, the entire CHMSL assembly must be replaced. For complete CHMSL removal procedures, see
center high mounted stop lamp removal in this section. For complete CHMSL system wiring information and diagnosis,
see exterior lamps/lighting electrical diagnostics also in this section.
REMOVAL
1. Disconnect the negative battery cable.
2. Remove the liftgate interior trim panel. Refer to Page
23-48.
3. Remove the retaining screws (2) from the liftgate.
4. Disconnect the center high mounted stop lamp (CHMSL)
harness connector (3).
5. Slide the CHMSL assembly (1) outward and remove from
the liftgate.
Old May 6, 2020 | 06:17 PM
DESCRIPTION
REMOVAL
23-48.
the liftgate.
There are a couple of threads which detail the repair of the CHMSL by members and a company that repairs them.
wootto
U.K.
Aug 16, 2020 07:55 PM
angelomd
Jul 20, 2019 08:37 PM
GeorgeC1031
May 15, 2012 03:07 PM
ALight
Jan 24, 2011 03:03 PM
No1Bobo
Apr 3, 2009 03:38 PM
