Jack Stand / Rear Axle
Old Oct 4, 2024 | 08:33 PM
intrvrt's Avatar
Default Jack Stand / Rear Axle
Hey everyone, have a question :
I ended up find a place to properly repair a cracked ream wheel on my 04 Coupe, thankfully they were able to get it in and I should have it back tomorrow.
Are there any places on the rear axle where I could support it with a jack stand, instead of the typical side pad for the OEM jack ?
It's sitting in a parking lot next to my building, just because my parking spot is unfortunately on an incline and I don't want to chance any incidents. At the same time - a public parking lot is making me a bit uneasy overnight as well.
Thank you !
Old Oct 7, 2024 | 02:02 PM
xintersecty's Avatar
Default Re: Jack Stand / Rear Axle
If you are just replacing a rear wheel, I would just use the jack stand. make sure the rubber bit is still there. If it's missing I just use a small block of wood to fit that shape. At the rear axel to put a jack stand do not put under the rear swing arms. It looks solid but not.
BibaResto
Oct 30, 2019 11:05 PM
Oconnom
Oct 2, 2014 11:09 AM
GraphiteGhost
15
Jun 27, 2011 10:02 PM
Hyperman
May 25, 2011 10:20 PM
ninsei
May 6, 2011 06:23 PM
