50K service
Old Aug 4, 2008 | 04:11 AM
leeroy's Avatar
Default 50K service
Hi all, been a while. My xf is at 50k now (04 model) I have just been quoted £545 for a one spanner service.
I recall a long while back I found a pdf on here somewher that detailed what was done at each service. SO two questions really. Has anyone got a list of whats done at what service? I though the one spanner service was just a oil change
Thanks
Lee
Old Aug 4, 2008 | 04:57 AM
maxcichon's Avatar
Default Re: 50K service
From page 247 of the owners' manual:
Your Flexible Service System (FSS) — see Understanding
Your Instrument Panel section — should give you an
exact indication of when your vehicle should be scheduled
for service and which schedule to follow.
Additional Periodic Maintenance
items should also be
performed beyond the items listed in the following charts
to assure the optimum performance of your Crossfire.
SCOPE OF WORK FOR “A” SCHEDULE
MAINTENANCE SERVICE
Oil Change
Change oil and replace filter
Maintenance
Lubricate hood hinges, latch, and secondary latch
Reset FSS Display
Function Check
Horn, hazard warning flashers, turn signals, and indicator
lamps
Headlamps and exterior lighting
Windshield wipers and washer system
Inspection
Check front and rear brake pads for lining thickness
Check tires for damage and general condition
Check tire inflation pressures and correct if necessary
Fluid Levels
Check fluid levels for the following systems and correct if
necessary. Should there be a loss of fluid that cannot be
explained by regular use, trace and eliminate the cause.
Engine cooling system (check corrosion inhibitor/
antifreeze)
Hydraulic brake system
Power steering system
Windshield washer system
250 MAINTENANCE SCHEDULES
MAINTENANCE
SCHEDULES
Old Aug 4, 2008 | 04:58 AM
maxcichon's Avatar
248:
SCOPE OF WORK FOR “B” SCHEDULE
MAINTENANCE SERVICE
Oil Change
Maintenance
Rotate tires
Replace dust filter
Reset FSS Display
Function Check
lamps
Check seat belts for damage and proper function
Test hydraulic brakes and check parking brake function
Inspection
Check condition of front and rear brake discs
Check major underbody components for leakage or
damage (if there are signs of leakage, determine cause
and repair)
Check condition of front axle ball joints and rubber
boots
Check condition of steering components and rubber
boots
Check underhood components for leakage or damage
(if there are signs of leakage determine cause and
repair)
Check condition of accessory drive belt
Check headlamp aiming, adjust if necessary
Check windshield wiper blades, replace if necessary
Old Aug 4, 2008 | 03:38 PM
E74778's Avatar
Thanks
Lee
Lee,
Seems a bit steep for a service because I was quoted £330 for a "B" service at my local Chrysler dealer.
If you know a local specialist who can carry out your service (correctly) then here is a link to resetting the service shedule
https://www.crossfireforum.org/forum...=reset+service
I know I am a lucky sod but one of my best mates works at a main dealer and I have just paid £77.00p for a main "B" service including genuine Chrysler parts and Mobil 1 oil, it's called "mates rates". He does go out on a limb with the oil and he carries out the service during his breaks.
Best thing to do is follow a mechanic home, find out the pub he drinks in and buy him a few pints.
Alan.
Old Aug 12, 2008 | 01:23 PM
zuikozoom's Avatar
I have just been quoted £575 for a £50K 4 year service whic apparently includes changing 12 spark plugs at £8+ each + VAT.
Can any one confirm tis is in the ballpark?
Many thanks
Grant
Old Aug 13, 2008 | 06:59 AM
norrie's Avatar
That sounds about right.
As said all 12 spark plugs need replaced and they are really expensive.
You can buy the spark plugs off E-Bay for £5.36 each including vat.
I would go to a local independent garage now it's out of warranty.
I would also buy my oil from somewhere like Cosco £37 for 8 litres when the dealer will charge you something like £80.
Have your air filters and fuel filters been done lately if not they miight need done as well?
The air and fuel filters are really expensive as well.
I think the fuel filter is around £80 and the air filters are around £50.
Norrie.
Old Dec 15, 2008 | 08:19 PM
kszoz's Avatar
So I got the double wrench -94 symbol when I started my car & went & got a load of Mobil 1 & a Fram oil filter (which I'll probably be returning & replacing with a fleece filter) - I'm at a little over 4k on my last service. Those of you who have had your XFs a while, how often do you change your oil? I do mostly city driving, unfortunately. Any suggestions?
Old Dec 16, 2008 | 12:15 PM
Steve - UK's Avatar
Norrie.
ZUIKOZOOM
The Air Filters (as are all other filters) are Merc Dealer parts for the SLK320 and are very cheap. I bought:
Oil filter £8.99
Air filters £23.00
Fuel filter £13.00
As norrie says shop around for the s/plugs and oil.
But if you do have to use a dealer, at least you can see how much profit you are paying them.
You can also go to any reputable mechanic, take him all the parts and just pay him his time.
If you lived closer to me I would do it for nothing! (or may be just the price of a pint!)
Steve
Old Dec 16, 2008 | 12:20 PM
Steve - UK's Avatar
I will change it as the service schedule wants - every 10K or every 12 months. It is top quality oil and it will work well for the recommended mileage. The beauty of a top mounted oil filter is you can change this without dropping the oil, so I will pop one in every 6 months just to help keep the oil clean.
Steve
RED DOG
-C-I-C-C-I Discussion
Oct 8, 2015 09:28 AM
DaveMe
U.K.
Sep 29, 2015 08:09 AM
Abaton6
Sep 24, 2015 10:14 PM
04Fire
Sep 15, 2015 07:40 PM
Mackel
Sep 15, 2015 04:33 PM
