Drivers Side Headlight
Old Jul 26, 2010 | 07:06 AM
Jonathan82's Avatar
Default Drivers Side Headlight
Gawd damnit. I hate having to change the damn things on the passenger side but the drivers side is just ridiculous.
I refuse to take it to the stealers though. No way Pedro. I will win!
Old Jul 26, 2010 | 07:28 AM
Chief's Avatar
Default Re: Drivers Side Headlight
Welcome,
Try looking under the technical section of the Forum. You may find your answer under Exterior & Lighting.
Chief
Old Jul 26, 2010 | 07:38 AM
Jonathan82's Avatar
I know how to change them. It's just very restricted on the drivers side so just wanted to share my frustrations as it were.
Old Jul 26, 2010 | 10:10 AM
Jonathan82's Avatar
Finished replacing both the bulbs on the drivers side, only to find out that it was a darn fuse problem all along and nothing wrong with the original bulbs.
Old Jul 26, 2010 | 03:01 PM
Mighty Quin's Avatar
Talking Re: Drivers Side Headlight
Thats funny, I spent hours trying this, and then got the shoelace advice and replaced them in about two minutes - you need a degree or a great forum to do this type of job.
Old Jul 26, 2010 | 03:21 PM
maxcichon's Avatar
Shoelace advice?
Please elaborate?
Old Jul 26, 2010 | 04:08 PM
Hairydalek's Avatar
I cheat. I pay Halford a fiver to do it for me.
Old Jul 27, 2010 | 06:35 AM
Jonathan82's Avatar
Halfords - I wouldnt let them fit my tyre valve caps.
I've had a horrendous experience with them in the past with a BMW M3.
Old Jul 27, 2010 | 08:21 AM
maxcichon's Avatar
What Is Shoelace Advise?
Old Jul 27, 2010 | 03:21 PM
Smile Re: Drivers Side Headlight
1. Take off the rubber cover covering the rear of the bulb
2. Unclip the wire bulb holder clip at the top, but leaving it on the hinge to hang
3. Get a thin and long shoe lace and tie it to the clip.
4. Secure the shoe lace to the front headlight casing with some gentle sticky tape
5. Unclip the hinge at the bottom of the wire clip, just squeeze it together at the base, the clip will pop off remaining tied to the shoe lace.
6. Pop out the old bulb and replace.
7. Get a small mirror and hold it in front of the rear of the bulb housing and reift the hinge at the bottom.
8. Once the bulb is secure - untie the shoe lace from the retaining clip and pop the top of the retaining clip back in place.
Sounds a little conveluted, but believe me when you do it, it is dead simple and takes less than five minutes and saves loads of work.
Old Jul 27, 2010 | 03:54 PM
Jonathan82's Avatar
Or, to do it in 60 seconds
Remove the rubber cap
Grab a hold of the black connector and pull hard
Once separated from the bulb, move connector out of way.
Study what's left and you'll see how the clip works with a hinge at one end and the other end which is held in place by a piece of metal
Push the clip to one side so it comes from behind the bit holding it in place.
You can then access the bulb and pull it free
Fit new bulb and reverse process.
Old Jul 27, 2010 | 04:03 PM
He means get the instructions, just like being told how to tie your shoe laces.
His answer was to give you the instructions, I guess he thought you did not know how to do it. You wrote the book on it. LOL
Old Jul 28, 2010 | 02:11 AM
Steve - UK's Avatar
Check this out, might help!
Changing The Front Headlight Bulbs
Old Jul 28, 2010 | 10:27 AM
Thats the condensed version.
Have a look at the REAL way to do it, if you cannot do it after reading this set of instructions you might as well slit your wrists.
HID's or regular bulbs the words and music still apply.
https://www.crossfireforum.org/forum/exterior-lighting/28907-hid-install-lows-fogs-pictures.html#post295727
Download and save the PDF file, print them and read them as you go.
This is the real way to tie your laces up.
Old Jul 28, 2010 | 12:33 PM
Steve - UK's Avatar
Don't know what all the fuss is about - it's a 10 min job!
Old Jul 29, 2010 | 02:56 PM
Sorry folks - I didnt read the thread right - I thought you had the same trouble as me and couldnt get the connection off the bulb lol thats why I explained this method. Steve is right - easy job, but when you cant remove the connector its a little tougher to get the bulbs out.
Old Jul 29, 2010 | 04:53 PM
maxcichon's Avatar
OK, thanks guys (all of/both of) you.
I kind of did write the book on it-just never had a problem with losing the clips-though many, many have.
Old Jul 30, 2010 | 04:28 AM
Steve - UK's Avatar
Main problem I had was that I put my new bulbs in upside down on first attempt (which did take more than 10 mins!) which gave me fantastic plane spotting abilities at night!
On second attempt I lost one of the clips inside the headlamp which was fun (that took more than 10 mins to fish out!) Finally after all that practice, the final attempt was much quicker. Now Ive just bought an HID set up, so more practice on the way!
My wife says it's a pity I've nothing else more important to do!
Old Jul 30, 2010 | 07:35 AM
maxcichon's Avatar
Well, you have the practice time in-so, no problem, right?
My wife doesn't say anything about the time I spend working/tinkering/playing with the car.
She realizes that we live in Alabama where wife-beating is not only legal but encouraged.
Sick attempt at humor. Sorry.
ardenian
19
Nov 21, 2015 12:00 PM
BrenLW
Aug 5, 2015 04:53 AM
Charles Moore
Aug 1, 2015 02:35 PM
Charles Moore
Aug 1, 2015 02:33 PM
michaelcycle58
Jul 28, 2015 08:12 PM
