Interior Lamp
Old Oct 7, 2010 | 04:44 AM
UK ken's Avatar
Default Interior Lamp
Need to remove interior lamp cover, re bulb replacment...
Don't want to damage the surrounds or unit. I have pressed here and there but with no success.. Any help or instructions available?
UKKen
Old Oct 7, 2010 | 07:55 AM
maxcichon's Avatar
Default Re: Interior Lamp
Ken,
you'll have to slowly and carefully pry the clear lens away from the housing. Pry at all 4 corners in sequence straight out. Do not tilt or tip as it is a bit brittle.
Once removed, I suggest instead of tweezing the bulbs out, remove the housing from the roof by taking out the 2 Phillips-head screws. The bulbs sit in little removable holders of their own.
If you push on them from below, they are easily damaged.
Cheers.
Old Oct 7, 2010 | 01:45 PM
UK ken's Avatar
Ken,
Cheers.
Thanks for info..will remove (hopefully) this coming weekend..will post ourcome..
Cheers
UKKen.
Old Oct 7, 2010 | 05:20 PM
andyd's Avatar
I did mine in the week. Used the info from this thread. (Look down the thread, there are some photos!)
https://www.crossfireforum.org/forum...ghts-leds.html
Hope this is useful.
Andy.
Old Oct 7, 2010 | 05:26 PM
andyd's Avatar
N.B. Once you have the main lens off, you don't actually need to remove the whole assembly to get to the bulbs. You can pull the little diffusers off and then just pull the bulbs out. I took the whole thing out as I had a faulty connection too, and to be honest I think I would prefer to remove the 2 screws that hold in the whole assembly and replace the bulbs from the back of the unit, rather than risk snapping the little diffusers!
Bulbs are code number 501 sidelight bulbs.
Regards.
Old Oct 7, 2010 | 06:27 PM
UK ken's Avatar
Regards.
Thanks, once carried out, I will report back..
Ken.
Old Oct 13, 2010 | 12:04 PM
UK ken's Avatar
Andyd Followed your instructions to the letter and remove unit..Now I have two lights..
Thanks
UKKen
TerryR
Dec 13, 2019 03:27 PM
eikon
Sep 9, 2019 10:16 PM
crossfireE
Oct 2, 2015 01:40 AM
MiamiTVR
Other Cars Etc
Sep 29, 2015 05:27 PM
jaesa
Sep 7, 2015 01:50 PM
