Pipercross air intake kit?
Old Dec 6, 2010 | 12:36 PM
Rowanbud's Avatar
Default Re: Pipercross air intake kit?
Perhaps this thread should be renamed 'Handbags at dawn' ???
Old Dec 7, 2010 | 11:33 AM
ZeroZero's Avatar
Hi SDnatist
Just my pennies worth , The chaps are correct about under bonnet air filters ,They will suck warm air , the better way is move the air filters forwards to the area between the grille & rad , If you look at where your intakes are connected to each side of the rad you will see a plastic molding which you can remove , So what i ended you doing was have some tube bent up to the same shape of the plastic tubes & got hold of some rubber tube to go thro' the holes each side of the rad & in the area behide the grille
If you do a search on this subject you should see a few setups .
Cheers
Andy
Dec 2, 2015 12:49 AM
Ralph289
Sep 21, 2015 09:34 PM
grip grip
Other Cars Etc
19
Sep 19, 2015 08:43 PM
81's
Sep 13, 2015 04:34 PM
Big Daddy
Sep 10, 2015 10:21 PM
