Exhaust smoke on tick over
Old May 3, 2012 | 08:03 PM
crossfire121's Avatar
Default Exhaust smoke on tick over
My car has covered 74500 miles . I had just driven about 15 mins on the motorway and as i parked up i saw exhaust smoke in the rear view mirror , i left the engine running and walked round the back and could see light blue smoke coming from the exhaust , it was'nt belching dark blue or smelt of bur'nt oil . Is this normal to see the exhaust fumes out of the exhaust. Oil level is ok and it drives ok temperature is ok as well. Just a bit worried about something expensive happening !!!
Old May 4, 2012 | 07:54 AM
Default Re: Exhaust smoke on tick over
There are 2 things that commonly cause blue smoke from the tail pipe :
1. worn valve guides/seals.
2. worn piston rings.
I would not think that under normal circumstances a W112 engine with 75K miles would smoke at all .....
Take it to a qualified mechanic for an opinion.
Old May 4, 2012 | 01:16 PM
Robskytoon's Avatar
A few other items spring to mind - overfill of oil - blocked breather
These people may be able to assist
Crewe Engines
Best of luck
TonyB
Old May 4, 2012 | 02:53 PM
Thanks TonyB , Where abouts is the breather on the engine ??
Thanks
Old May 5, 2012 | 11:28 AM
Robskytoon's Avatar
Blocked breather pipe may be a red herring was thinking non Mercedes engines as they have this complex emission system with air pump, talk to the Crewe people next week
Old May 5, 2012 | 01:15 PM
Am i reading your post wrong about non - mercedes engines ? thought the crossfire did have a mercedes engine !!
Thanks for replys
Old May 6, 2012 | 03:03 PM
Robskytoon's Avatar
When I posted re breather pipe I was thinking generally not mercedes; the merc engine in a crossfire has a complex emissions system which includes the air pump which you rarely find elsewhere. It could be something as simple as worn stem seals but that would mean a top end strip - you need a professional diagnosis
TerryR
Dec 13, 2019 03:27 PM
minimayhem
16
Aug 23, 2016 07:47 AM
cuziamninja
Oct 5, 2015 10:39 AM
Charlesl
Sep 30, 2015 10:46 PM
Sep 28, 2015 07:40 PM
