Rear wheel Hub
Old Oct 13, 2013 | 08:59 AM
crossfire121's Avatar
Default Rear wheel Hub
I have a wheel bolt which just spins around and i cannot get it out. Which other models of Mercedes share the same rear hub assembly as i may have to look for a seconhand one. Thanks.
Old Oct 13, 2013 | 09:03 AM
Default Re: Rear wheel Hub
It would be cheaper and easier to put a HeliCoil insert in the existing one. It should be done by someone who knows what they are doing.
It has been done before here on the forum. It would be best to take the hub off and have it machined but some have done it while the hub was still on the car.
Old Oct 13, 2013 | 09:13 AM
Good idea , how would i go about removing the bolt that spins around , i was thinking could someone weld a T-bar to the head of the bolt and then someone pull and rotate the T - bar until it bites.
Old Oct 13, 2013 | 09:28 AM
I'd let someone weld anything close to that expensive wheel ...... I think NOT.
This problem was discussed recently, unless this is the same poster.
Roty135
17
Oct 11, 2018 10:11 AM
cdcrone123
27
Sep 24, 2015 11:28 AM
cdcrone123
Aug 4, 2015 06:37 PM
tom2112
Jul 28, 2015 08:12 AM
Buchacho
Jul 9, 2015 04:13 PM
