Beeping noise from dash
Old Feb 27, 2021 | 07:29 AM
bamp's Avatar
Default Beeping noise from dash
Hope someone can give some advice, when I put key into ignition and turn the key (but not start the engine) I get @ continuous beeping noise. The engine will start but the beeping keeps going. There are no warning lights on the dash, everything seems normal. All doors, bonnet, tailgate etc are fully closed so not sure what the bleeps mean.
Old Feb 27, 2021 | 03:41 PM
Default Re: Beeping noise from dash
Give us more to go on:
Coupe or Roadster?
Auto or Manual?
Base-SE, Limited or SRT?
Old Feb 27, 2021 | 03:51 PM
bamp's Avatar
2006 coupe auto UK version so guess limited
Old Feb 27, 2021 | 07:50 PM
zip439's Avatar
You might try disabling your seat belt chime:
1) Turn the key to on/START - within 60 seconds, turn ignition off
2) Start engine and wait for seat belt light to turn off
3) Within 60 seconds unbuckle/rebuckle the seat belt 3 times ending with buckled, it should chime once; this confirms you have turned the chime off.
Old Feb 28, 2021 | 06:25 AM
bamp's Avatar
a constant beeping - def not a chime.....tho i did try the seat belt chime late last night as suggested but it made no difference.
***update****just been out this morning to do some other checks as kindly suggested by those more technical than me, popped key in ignition and the beeps have stopped.....after 2 days of beeping, now back to normal...very weird indeed.
Old Feb 28, 2021 | 10:08 AM
Christine !!!
Old Mar 1, 2021 | 11:37 PM
it was the little nash rambler going BEEP BEEP now he got it out of second gear he left you in the dust no more beep beep
cross4ya
May 11, 2016 01:52 AM
Alabaster xfire
Feb 13, 2014 01:19 PM
89bird
Jun 23, 2009 05:17 PM
holgo123
Feb 7, 2009 05:57 PM
D&D
Jan 2, 2009 04:27 PM
