Recommeded Parts!
Old Sep 5, 2022 | 01:47 PM
Peter Hart's Avatar
Default Recommeded Parts!
I own a 2004 Crossfire Coupe, which needs a service & would like to know recommended parts such as:
Air Filter;
Automatic Transmission Fluid;
Battery;
Brake Fluid;
Coolant;
Engine Oil;
Fuel Filter;
HT leads;
Oil Filter;
Power Steering Fluid;
Spark Plugs;
Sump Gasket & diameter;
Windscreen Wipers.
Thank you,
Advice would be very much appreciated!
Peter
Old Sep 5, 2022 | 04:10 PM
Default Re: Recommeded Parts!
Index of Crossfire problems and repairs - CrossfireForum - The Chrysler Crossfire and SRT6 Resource
It should all be in the manuals section.
Old Nov 21, 2022 | 01:46 PM
THETESTER's Avatar
Hi Peter
Are you still looking for the info?
Let me know and I will dig out the part numbers and best suppliers for you.
Old Nov 23, 2022 | 07:05 AM
Peter Hart's Avatar
Thank You!
I am still requiring the parts!
Your help will be much appreciated.
Kind regards
Peter Hart
Old Nov 23, 2022 | 07:51 AM
THETESTER's Avatar
Originally Posted by Peter Hart
Thank You!
Kind regards
Peter Hart
Peter, will get the info to you, hopefully tonight.
Old Nov 24, 2022 | 03:09 PM
THETESTER's Avatar
Hi Peter
Sorry for the delay in getting the info to you.
These part numbers are from my past purchases. Please ensure the numbers are still valid for your requirements.
The prices on the parts listed vary from supplier to supplier. I have always used the following and then go to the company with the best price. Please be aware that a couple of these firms have merged, but their prices can vary from day to day.
1. Euro Car Parts
2. CarParts4Less
3. BCC Autofactors
4. GSF
Some items are only available from the likes of Halfords. Be aware that Halfords prices are up and down like a yo-yo. It would be beneficial to join the Halfords motoring club as you get regular £5 discounts that can help bring the prices down.
Air Filter; Part Number (C2861-2) these are Mann Filters: -
Automatic Transmission Fluid; Not purchased any myself.
Battery; B096SPPLA – National Tyres and Autocare did have the best prices with great warranties.
Brake Fluid; Not purchased any myself
Coolant; Comma Xstream G48 – Only ever found it at Halfords.Be aware it is critical that you ensure all the old coolant is removed to ensure there is no contamination which can cause problems for the aluminium engine.
Engine Oil; Mobil 1 – 0W-40 Halfords had the best price when I changed the oil this summer.
Fuel Filter; NOT a part to change yourself
HT leads; Never changed mine
Oil Filter; Part Number (HU718/5X) this is a Mann Filter: -
Power Steering Fluid; Not purchased any myself
Spark Plugs; Not purchased any myself
Sump Gasket & diameter; Do you mean sump gasket or sump plug gasket?
Windscreen Wipers; Bosch, I do not have the part number to hand.
Rear Axle Fluid; Part number Fuchs Titan Sintopoid FE SAE 75W-85 – supplier OPIE OILS (Ebay)
Additional Items:- Personal Choice
Rear Brake Pads; Part Number Brembo (BREP50025 / 646ME0470)
Hope this helps
Old Nov 25, 2022 | 11:50 AM
I order plugs, wires, etc. from NEEDSWINGS.COM here in the USA. I have no idea what part number, I order from Rob because he knows what is needed.
For my differential, I used Mobile 1 75W90 under advice from the real "tech heads" here on the forum.
Engine oil is any of the 5W40 full synthetics that has "MB229.3" on the side. I would avoid 0W40 unless you are in a cold climate (which you may be).
Full list of approved oils is here:
https://operatingfluids.mercedes-ben...sheet/229.3/de
Power Steering and convertible top uses Pentosin CHF11S.
Brakes use DOT4 here in the USA, I do not know how brake fluid is rated in the EU. This site is MB's information page that might be helpful:
https://operatingfluids.mercedes-benz.com/
Other than the air filter, the engine is an M112 which was used in the SLK320, you can search "2003 MB SLK320" for plugs, wires, and most fluids and be just fine. In fact, that is what I do.
In the USA, the Fuel filter is a Mann WK720. But over there, I would search "MB SLK320 fuel filter", and I would expect the search to yield a BOSCH part. I BELIEVE the BOSCH number is 0 450 915 003 0.
Old Nov 28, 2022 | 06:51 AM
Peter Hart's Avatar
Thank you to The Tester & Pizzaguy, the information supplied is very much appreciated!
Please confirm a good for a right-hand front lamp unit?
Kindly confirm whether one can obtain replacement glass lenses to replace the plastic ones or a good cleaner?
Best regards,
Peter Hart
Old Nov 28, 2022 | 11:47 AM
Best regards,
Peter Hart
No glass lenses available.
XFireCrazy
Nov 28, 2022 06:43 AM
Rubchris527
Apr 23, 2013 07:01 PM
Chopchop
Jul 17, 2012 07:30 AM
maxime75us
Jun 9, 2012 08:07 AM
caddymike85
Dec 5, 2011 08:38 AM
