Tire Pressure - Ambient Temp.
Old May 30, 2006 | 01:33 PM
SWELLCLUB's Avatar
Default Tire Pressure - Ambient Temp.
Does the ambient temperature impact a tire pressure reading? I kept my tires at 32 psi (door sticker) but yesterday when the ambient temp was 90 degrees and I had not driven the car, all the tires read 35 psi.
Could this be because it was hot outside?
Old May 30, 2006 | 01:58 PM
fuzz 40's Avatar
Default Re: Tire Pressure - Ambient Temp.
Yes, and if it gets colder then your tires will drop in pressure.
Old May 30, 2006 | 02:00 PM
danimal's Avatar
Pressure will fluctuate about 1 lb for every 10 degrees or so.
Old Jun 19, 2006 | 10:14 PM
04Fire's Avatar
While our/my door label says 32 psi front and 33 psi rear my dealer keeps raising all of them to 39 psi.!? Is that right? I reset them to the proper (door label) psi once I get back home. As anyone else had this problem?
Old Jun 19, 2006 | 11:59 PM
maxxm's Avatar
Well, we already know that most Chrysler dealers cannot service this car correctly, but we didn't know they couldn't read either. For whatever reason, though, my wife's Audi dealer just did the exact same thing -- even though here in Arizona it's already 110 degrees and the tires are growing and growing...
Old Jun 20, 2006 | 06:28 AM
bobs's Avatar
I'll bet the mechanic was reading the tire's sidewall where it says "do not exceed 40 psi to seat bead".
Old Jun 20, 2006 | 07:11 AM
danimal's Avatar
I don't believe mechanic's CAN read!!! At least, not the ones that are supposedly crossfire certified. Haven't heard of too many of them doing anything right, even with a service manual.
Old Jun 20, 2006 | 08:22 AM
aschrager's Avatar
If you drove home and the pressure was 39 and you lowered it when the tires were hot the pressure will be below the 32 or 33 lbs when cold. Only check when they are cold.
Old Jun 20, 2006 | 10:45 AM
04Fire's Avatar
Thanks charger, I waited for a few hours after I got home then adjusted it to the proppor cold tire pressure.
It amazes me how someone could mis-read the tire pressure label. You'd think that would have been covered in the first week of mechanic school.
Jonacross
20
Jul 17, 2017 11:19 PM
SRT6_Roadster
Sep 24, 2015 04:40 AM
stelrz1
Sep 21, 2015 11:18 AM
Idrenak
Sep 19, 2015 08:17 PM
lazorouss
Sep 11, 2015 09:16 AM
