235/35/19? and 20x8.5 back? 255/30/20
Old Dec 12, 2007 | 03:48 PM
tylerxfire's Avatar
Default 235/35/19? and 20x8.5 back? 255/30/20
i recently purchased niche venice black wheels for my roadster and the company recommends 235/35/19 on front with 19x8.5 and 255/30/20 on back with 20x8.5, i see others running 20x10 with like 275's is my car gonna look ok and not have rubbing issues, they say it will be fine and be very close to stock dimensions. i don't want to have to use spacers, just want a nice look with no rubbing. whats everyone think?
Old Dec 12, 2007 | 05:34 PM
MMZ_TimeLord's Avatar
Default Re: 235/35/19? and 20x8.5 back? 255/30/20
The sizes you stated are VERY close to the OEM overall wheel/tire size combo.
On the Fronts, the overall height will be 25.2" where the OEM is 25.1"
On the Rears, the overall height will be 26.1" where the OEM is 26.0"
So your speedometer will only be off by a little. (less than a tenth of 1%)
The biggest issue is going to be getting the proper offset for the new rims. If they don't match the originals or are very close, you MAY have rubbing issues.
I had to put a 7mm spacer on my rears to get them not to rub at full suspension travel (up).
Old Dec 13, 2007 | 02:08 PM
tylerxfire's Avatar
so will 20X10 be ok on the back with 275/30/20?
Old Dec 22, 2007 | 05:57 PM
cgt_n_the's Avatar
You should be fine with the right offset. Niche make a nice wheel but hay I'm biased... F-18's on my ride...
https://www.crossfireforum.org/forum...5&d=1148520547
NeedsWings
70
Mar 24, 2023 09:48 AM
theglot
Sep 24, 2015 07:56 AM
headlock0003
Aug 17, 2015 11:26 PM
Arm_and_a_Leg
Aug 14, 2015 12:25 PM
michaelcycle58
Jul 28, 2015 08:12 PM
