Best Tire size ??? 20X8.5
Old Jul 2, 2010 | 11:40 PM
firemen's Avatar
Default Re: Best Tire size ??? 20X8.5
Dwight is right. ( )! I think it looks like a 19/20 staggered set. That's what I run. I added spacers to keep OEM offsets (35 Front/22 Rear), then needed 5 mm more to clear that darned ball joint nut in front.
Be aware that the tire width (225 or 235) along with the taller profile (only 1/4") might get you too close to the upper ball joint nut. Spacers needed then Not expensive ($50-$75 US/pair).
with oem offsets can I definitely afford spacers even in a drop? I look at other forums and it says that the lower the offset the better to a certain point.
BrenLW
Aug 5, 2015 04:53 AM
onehundred80
Aug 2, 2015 11:37 AM
onehundred80
Canada
Jul 24, 2015 03:50 PM
crymar
Jul 17, 2015 08:46 AM
syfi
Jul 12, 2015 05:59 PM
