Wiil these wheels work?
Old Mar 10, 2008 | 07:49 AM
pennstatebadboy's Avatar
Default Wiil these wheels work?
I'm getting new wheels for my 06 limited coupe. Is there anything I need to be concerned about with wheels that have the following measurements?
18X9 5-112 35HSM
http://www.discounttiredirect.com/di...112&vid=011477
19X9.5 5-112 35HSM
Will these fit without modifications? Is the offset ok? Will they rub? Will they interfere with the ESP system? Will the tire pressure sensors work with them? Will they look ok?
Is there anything else I should know?
Thanks!
Oh, alternatively, the 18's come in this size. 18X8 5-112 32HSM. Is that better?
Old Mar 10, 2008 | 10:32 AM
NoCones's Avatar
Default Re: Wiil these wheels work?
18X9 5-112 35HSM
19X9.5 5-112 35HSM
Thanks!
A lot depends on the tire you choose to put on there.
The 18x9's will be awfully close to rubbing the upper ball joint bolt in the front with just about any tire you put on that makes use of all that width.
In the rear, you should be fine. A spacer to get closer to stock offset might be nice, but not a big deal to be without.
Old Mar 10, 2008 | 10:37 AM
Thanks, Bryan. Will the 18X8 5-112 32HSM wheels be ok in the front without spacers?
Old Mar 10, 2008 | 12:03 PM
NoCones's Avatar
yes...assuming you're not planning on some ridiculously wide/tall tire.
Old Mar 10, 2008 | 01:04 PM
No. Just the OEM tire size.
Roty135
17
Oct 11, 2018 10:11 AM
tom2112
Dec 1, 2015 09:02 AM
2004_
Jul 11, 2015 03:14 PM
Buchacho
Jul 9, 2015 04:13 PM
Blackout317
Jul 7, 2015 08:38 PM
