Tire Bubbles
Old Apr 18, 2008 | 10:20 AM
rodimus's Avatar
Default Tire Bubbles
I've been a proud Crossfire Owner since October..... I'm on my 2nd and half set of conti's now- Due to my 3rd bubble????? Please tell me this is not normal. What tires would you all recommend??
Thanks for your help-
07 X-Fire Limited Coupe
Old Apr 18, 2008 | 10:35 AM
spensley's Avatar
Default Re: Tire Bubbles
I think there have been other complaints about tires bubbling, but I can't remember whether they were Contis or not.
Try searching.
Old Mar 11, 2009 | 09:12 PM
LadyMills's Avatar
15k miles and both my back tires have developed bubbles, plus I seem to be a magnet for nails. 4 flats in one year? Seriously? What is up with these tires???
I just noticed these bubbles (one on each back tire.) How long can I drive these before they have to be replaced? I have to go out of town this weekend. :-(
Old Mar 12, 2009 | 03:01 PM
MannyTwoTwo's Avatar
When I purchased my XF it came equipped with Pirellis and the passenger front tire had a bubble which I drove around with for several months with no problem. A coworker a mine just told me a couple of days ago that his girlfriend had a bubble on one of her tires and he told he told her not to worry and mentioned my situation and guess what....that's right, she had a blow out. Luckily, she was not driving on the highway nor going fast so the moral of the story is don't drive around for too long with a bubble on the tire because you never know. I ended up purchasing some General Exclaims and have been very happy ever since.
Good luck and hopefully you can resolve your problem.
Old Mar 12, 2009 | 04:14 PM
07bluezx14's Avatar
I would definately get some different tires, if the same ones keep getting bubbles. Doesn't sound safe to me.
Old Mar 12, 2009 | 05:02 PM
Squirrel Crusher's Avatar
I had to replace one front Conti. Tire distributer say I must have turned into a parking lot concrete aporn to fast. Maybe I did. I'll be putting 16 or 17's on when these wear down. Squirrel Crusher
Old Mar 12, 2009 | 06:02 PM
Kurts's Avatar
Bubbles (& I'm assuming they're in the sidewall) are nearly always caused by one or two things: either incomplete bonding of the layers during manufacture or by hitting lotsa potholes. Usually defects in manufacturing show up fairly quickly, under a year or so.
So, no, it's not normal.
And, yes, they're dangerous simply because they have a tendency to blowout.
Personally, I'm a big fan of the Goodyear F1 A/S though they have a tendency to get noisy when they wear.
Old Mar 13, 2009 | 07:03 AM
srt6shadow's Avatar
Found a bubble in the right rear of my wife's ps2's after inside patching a screw in it yesterday, looks like a good time for those 285/30 proxes.
Old Mar 13, 2009 | 09:42 AM
///SilverSaphRT6's Avatar
When I purchased my 6 in Oct 08 the front Continentals had flat spots in them and made a clunky noise upon deceleration. I changed to Hankook's problem solved. Not bubbles but I would recommend Hankooks...they are nice tires IMO.
Old Mar 16, 2009 | 09:38 AM
Chris L.'s Avatar
I had a "slipped belt" on one of the original front Contis & had to replace them at 17K miles.
Old Mar 16, 2009 | 10:18 AM
LadyMills's Avatar
I ended up going to Discount Tire before my trip to San Antonio. I almost fainted when I found out how much 19" tires cost. But the manager told me he had a guy come in with a brand new Mercedes Roadster and swap out the new 19" Bridgestone tires for some other ones. They still had the sticker and nubbies, but were technically "used" tires. They were 275/35, and they fit!!! $75 bucks each. I couldn't help myself, I bought them. I simply didn't have $600 to drop on a new pair of tires before my trip. I hope I made a wise decision. They sure do stick, WOW!
Old Mar 16, 2009 | 10:51 AM
SteveS's Avatar
Originally Posted by MannyTwoTwo
... the moral of the story is don't drive around for too long with a bubble on the tire because you never know.
that's exactly right ... you never know ... a bubble is an indication of a separation of the plies in the tire ... it's a sign the tire has weakened and is not holding air as it is designed to do ... and, as you've observed, a blowout can easily occur ... and, at highway speed, that could be a fatal problem ... a tire with a bubble should be replaced ASAP ...
Old Mar 16, 2009 | 03:07 PM
TBird's Avatar
I had the same problem on my first '04. Two out of four of the Conti's went bad. Switched to Bridgestone Potenza's. No problems. Where I turned the 04' back in to the dealer they got the Conti's back. It was a lease.
My next two Xfire's have both been switched to Bridgestones. I kept the Conti's in case I need a spare.
TerryR
Dec 13, 2019 03:27 PM
Jonacross
20
Jul 17, 2017 11:19 PM
Mackel
Sep 29, 2015 02:41 PM
SRT6_Roadster
Sep 24, 2015 04:40 AM
stelrz1
Sep 21, 2015 11:18 AM
