General Exclaim UHP ?
Re: General Exclaim UHP ?
Originally Posted by Fired UP
Discount Tire said they would be in this week, If so I will get them installed Friday. I will take the pics then and share on this thread. Hope all of this helps in your decision.
I just got my rears (Stock-255/35) swapped out for the (275/30) at Discount Tire (for free),,,,,, great customer satisfaction policy.
Wider, Oh Yes....but you loose a 1/2 inch on overall height. To me this is not very noticeable, because the 255's pulled the side wall in and made the tire look narrow on the rim.
WOW... way better looking and the rim is much better protected.
The side wall stands straight up, like it should.
I will post the pics ASAP.
275/30
on
Thanks for the pics, they do look better! Good choice. Why did you go with the '30' and not '35' or '40' ratio? Just curious before I jump in.
James
James
275/30 was the largest 19" available for the General UHP.
I would have gone for a 275/35 or even a 275/40 if it was available.
Hey James...
The fronts look good as they are now.
Originally Posted by scott
I now have 1.75 miles (distance from tire store to my home) on my General Exclaim UHPs (stock sizes front and rear). As soon as I have some miles on them I post a report that says something other than I like the way they look...
Did you notice the rear tire side wall pulls in from the outside edge of the rim?
This was why I went with the 275/30's.
Well, I had mine for a week now and they have been getting a great deal of work in the rain due to Fay. So far they are really sticking to the road in wet weather. The first test was going right through some standing water at about 50mph. I didn't see the standing water until it was too late because the area was poorly lit but the tires seemed to cut right through the water. I have even tried to fishtail the xf to no avail. Needless to say they stick even better on dry roads. I'll keep updating as time goes by.
I like them as well, when launching off the freeway on ramps I have a hard time getting them to break loose.
Here in San Diego we don't get that much rain but over the last couple of weeks we got a little, the problem here isn't allot of water on the roads but just enough to lift the oil and there you have it "slip-slide off the side", we see this all the time. I have had no problem at all with these tiers.
I agree that the tread pattern looks very good.
Nice and aggressive.
The specs for those 275/30/19s say they should go on wheels that are 9.5 to 11 inches wide......but the OEM wheels are only 9.0 inches wide....????? Isn't there a chance something nasty could happen while taking a corner/curve at real high speed?????
My mistake.....some of the other brands say 9.5-11.....but the Generals do say 9 = OK.
Hey all. I am now on my second set of UHP's. Currently on a set of 275/30-19's And I have put these through some serious corners with our colorado crossfire group and on my own. I have had no problems with these being "too wide" for the wheels, and they have got some serious sticky sticky traction. They have even gotten me through the last two winters of colorado without any serious heartburn. Great price, great buy. Will keep using them with no questions.
