Springs First And Then Shock Absorbers?
Old Aug 9, 2008 | 04:16 AM
iduesoli's Avatar
Default Springs First And Then Shock Absorbers?
Hi there! I have a 2005 Roadster Limited; I would like to lower it a little bit; I am going to buy the Eibach ProKit set springs; can I leave on the original shock absorbers? If not, what absorbers do you suggest? Koni or Eibach or what? Thanks again. Riccardo
Old Aug 9, 2008 | 06:00 AM
m3pig's Avatar
Default Re: Springs First And Then Shock Absorbers?
I kept my stock shocks...don't forget to shave the bump stops.
Old Aug 27, 2008 | 07:23 AM
iduesoli's Avatar
Hi everybody! Tomorrow I'll have installed the Eibach Pro kit Springs on my Roadster; anyway, no posts on shaving the bump stops: why???
Old Aug 27, 2008 | 04:55 PM
Fritzauf's Avatar
O.K.... If you use the stock shocks you can cut 1/2 inch off of the bump stops. Do a search and you'll find plenty of information on this.
I installed the Koni adjustable dampers when I installed my Eibachs. I just really like them. You have to drive my car to know what I'm talking about. I highly reccomend them. It's a smooth ride not harsh at all but tight in the turns... like it's on rails. VERY responsive but doesn't rattle your teeth.
Old Aug 27, 2008 | 05:06 PM
andrew's Avatar
-C-I-C-C-I Associate Member
~ they are located in the rear shock (a round block of hard rubber that surrounds the shock piston under the dust boot).
easy to do...can be trimmed down with a utility knife.
Old Aug 30, 2008 | 07:54 PM
racermp's Avatar
i don't understand why ppl cut the bumpstops, this sort of saves the shocks cuz shocks blow out when they bottom out, the bump stops stop the shocks from bottoming out.
i always leave the bumpstops as they r when dropping cars, there is still plenty of travel.
but am i thinking wrong that bumpstops will stop a shock from bottoming out, eventually saving the shock?
deerhunter
Jan 16, 2021 10:56 AM
onehundred80
Aug 6, 2016 12:03 PM
2005 Ragtop
Oct 3, 2015 03:01 PM
ayebb
Sep 18, 2015 03:35 PM
mattnelson71
Jul 30, 2015 10:49 PM
