Finally Lowered my Car
Old Mar 17, 2009 | 09:06 AM
  #41 (permalink)
Default Re: Finally Lowered my Car
I think this picture is a better before and after shot.
Old Mar 17, 2009 | 09:19 AM
  #42 (permalink)
Mad_Med05X's Avatar
WOW!!!
Was that set up $9.99 plus shipping
Old Mar 17, 2009 | 09:44 AM
  #43 (permalink)
///SilverSaphRT6's Avatar
Very nice.....what kind of camera are you using?
Old Mar 17, 2009 | 09:52 AM
  #44 (permalink)
I have a Nikon D40-X.
Old Mar 21, 2009 | 01:40 PM
  #45 (permalink)
FrSailorman's Avatar
Great job FP !!!
Have you trimmed the rear bump- stops by 20mm as required or do you think it's not useful ??
Old Mar 21, 2009 | 02:09 PM
  #46 (permalink)
Originally Posted by FrSailorman
Great job FP !!!
Yes I did.
Old Mar 21, 2009 | 06:44 PM
  #47 (permalink)
Easy to do ?? or does it take time ??
Old Mar 21, 2009 | 07:32 PM
  #48 (permalink)
I paid to have mine done by a MB mechanic. So I don't know if it's difficult, but I know he did.
There are several member who did their own, maybe they can comment.
Old Mar 21, 2009 | 10:10 PM
  #49 (permalink)
Hey Andrew,
You've lowered quite a lot your car. Do you know how much ?? Have you used lowering springs only ??
THX
Old Mar 22, 2009 | 06:17 AM
  #50 (permalink)
Hey Andrew,
THX
I have the Eibach and it lowers it as follows;
1.2 rear
1.0 front
Old Mar 22, 2009 | 07:16 AM
  #51 (permalink)
andrew's Avatar
-C-I-C-C-I Associate Member
Hey Andrew,
THX
my car had one of the first eibach sets on it (m/b slk s320) in late '04. it is slammed/very low by comparison of today's available eibach pro-kit set.
i truly think eibach revised the kit and raised the lowering height. my car dropped at least 2 inches.
here are my ride height measurements: (note yard stick is from the ground up).
(front):
(rear):
i am very happy with the changes. i also added koni adjustable shocks to complete the suspension. however the shocks are not required...i just like a crisp rebound.
i purchased my eibach pro-kit suspension thru the: tirerack.com.
hope this helps!
Old Mar 22, 2009 | 10:16 AM
  #52 (permalink)
That's great feedback from you guys !!
Have both of you replaced your spring pads also ??
Old Mar 22, 2009 | 10:20 AM
  #53 (permalink)
Just another question :
Is one of you aware of those springs that lower your car 1.75 or around :
http://www.eautoworks.com/product-Sp...-Crossfire.htm
Old Mar 22, 2009 | 10:27 AM
  #54 (permalink)
have any of you driven yours really hard through corners, and does the body roll creat any problems?
Old Mar 22, 2009 | 11:12 AM
  #55 (permalink)
I think it handles better.....
Old Mar 22, 2009 | 01:08 PM
  #56 (permalink)
acrispy1's Avatar
I agree with FP it handles better.
Old Mar 22, 2009 | 07:51 PM
  #57 (permalink)
andrew's Avatar
~ stock spring pads.
Old Apr 14, 2009 | 08:06 AM
  #58 (permalink)
Mad_Med05X's Avatar
Originally Posted by andrew
without spacers:
with spacers:
looks much better pushing the rim & tire closer to the wheel well edge imo ... hope this helps!
I put my lowering springs on last week! The car looks good! Nevertheless, I did not see any rear bump stoppers on the back!
As far as spacers go.... Is this the best way to go...12mm in the back and 10mm in the front?
Old Apr 14, 2009 | 08:14 AM
  #59 (permalink)
I think so. That's what Andrew had on his. As do most of us that have spacers.
Old Apr 14, 2009 | 09:45 AM
  #60 (permalink)
patpur's Avatar
Senior Member/Moderator
Ok here's a question - have any of you that have lowered your cars had the alignment adjusted afterwards? I'm trying to figure out what all is involved in doing this. Sean know how to do springs, he's done enough of them in our garage but it seems that whenever he does them the cars are out of alignment and they have to be aligned including his RSX. I am also reading here and Tony you backed this up that there is no noticeable change in the ride. Yes I am considering it but I want to know what I'm getting into first. As for the spacer issue the wheels I run are supposed to be the same offset as the stock wheels so I guess I would have to do the spacers as well.
Thanks - Pat
