Finally Lowered my Car
Old Sep 30, 2008 | 03:01 PM
Default Re: Finally Lowered my Car
Well, I called to see if I had any chance of getting my spacers by Friday, but no luck. I will probably get them Monday or Tuesday next week.
I was hoping to have them on for our Chicago-Land GTG this Sunday.
Old Sep 30, 2008 | 04:33 PM
+fireamx's Avatar
Not trying to be "negative" but be prepared for:
http://en.wikipedia.org/wiki/Camber_angle
Old Oct 1, 2008 | 03:26 AM
crossfirefrank's Avatar
Andrew - did it effect ride / handling? Did you have problems with tire wear? What was the offset?
Old Oct 1, 2008 | 05:38 AM
Frank,
do ya have some $$ burning a hole in your pocket ?? lol
Old Oct 1, 2008 | 07:23 AM
tom2112's Avatar
She can ride with me ;)
Forget the spacers, FP. Get those rims chromed! I'm shocked that you haven't already.
Old Oct 1, 2008 | 07:40 AM
I would if I could find someone local to do it. I don't care to pay $400 for shipping both directions from California.
Old Oct 1, 2008 | 10:08 AM
tom2112's Avatar
Even better idea: road trip to California!!
Old Oct 1, 2008 | 10:51 AM
Voyager's Avatar
oh YEAH! that sounds awesome what is that drive like 28 hours.
Old Oct 1, 2008 | 08:17 PM
NeverEnough's Avatar
So, maybe Andrew can tell us, is there an adverse affect on the tire wear after lowering? I know Andrew had this set up for a while... If tire wear problems are not a big issue, I'm doing this next. Of course, if Camber becomes a problem, so will traction, as the tires won't be making consistent contact pressure accross the tread...
Old Oct 1, 2008 | 10:21 PM
newCrossfire's Avatar
i think its amazing how this kit doesnt affect ride quality at all. most kits you see peoples cars bounce off every minor imperfection in the road. its really unchanged from factory.
Old Oct 2, 2008 | 03:50 AM
andrew's Avatar
-C-I-C-C-I Associate Member
Originally Posted by NeverEnough
So, maybe Andrew can tell us, is there an adverse affect on the tire wear after lowering? I know Andrew had this set up for a while... If tire wear problems are not a big issue, I'm doing this next. Of course, if Camber becomes a problem, so will traction, as the tires won't be making consistent contact pressure across the tread...
i had my set up on the car for nearly 40k the tires wear was even across the entire tires at the end of their life... i was on my second set at lease return...
the ride is truly near factory... just less roll... and great looking ascetics.
Old Oct 2, 2008 | 06:18 AM
chuck65's Avatar
Looks great FP. I'd consider doing the same but as you get older (I'm not even suggesting that you are). It gets harder to get in and out of your car. If mine were any lower I'd have to roll out sideways onto the ground and crawl over to the nearest vertcal object and pull myself up.
Anybody know where I could find a good 10" riser kit for a Crossfire?
Is that spacer you guy's are talking about something that I could stap onto my *** so I could sit higher in a lowered Crossfire?
Old Oct 2, 2008 | 06:23 AM
tom2112's Avatar
Hey Chuck, since you have a roadster, you could install a scissor-lift under the driver's seat. Just don't use it with the top up!
Old Oct 2, 2008 | 07:23 AM
Gary - you know me always looking for something to improve the looks. OK since Andrew confirms that tire wear won't be an issue can someone point me in the direction of best place to purchase these and what sizes work best.
Old Oct 2, 2008 | 08:53 AM
So far the best pricing I've found on the springs is at TireRack.
Old Oct 2, 2008 | 09:58 AM
maxcichon's Avatar
Looks great FP. I'd consider doing the same but as you get older (I'm not even suggesting that you are. It gets harder to get in and out of your car. If mine were any lower I'd have to roll out sideways onto the ground and crawl over to the nearest vertcal object and pull myself up.
How about something like this?
Only put the airbag under the seat!
Old Oct 2, 2008 | 02:20 PM
tom2112's Avatar
Hey Max, I think someone has been doin the nasty in your car. That seat is pregnant!
Hey! That must be how they make baby seats.
Old Oct 2, 2008 | 02:45 PM
  #38 (permalink)
MAYAman's Avatar
Nice FP!! And seeing Andrews car makes me sad.
Old Oct 2, 2008 | 04:01 PM
  #39 (permalink)
looks good FP...that is also on my to do list...and I am glad Andrew chimed in...cause I was worried about the alignment as well, even though I have access to a rack...there isn't any adjustment available without modification...
Old Oct 2, 2008 | 06:55 PM
  #40 (permalink)
maxcichon's Avatar
Smarta$$!
Isn't that the ugliest thing you've ever seen?
It was in a thread some time ago by a fella' that needed lumbar support. I guess it worked, but OMG!
I saw a episode of Ridin' the Low Life (!) and watched some old geezer do absolute MAGIC to make a custom seat for just that problem. Just carefully shaved foam glued to the original foam. Looked great and the customer was really happy.
I spoke to a local uphlosterer and he said it would cost me $100 all in to have it done. 2 days though...my back sure would be happy!
