klunking noise when turning?
Old Dec 1, 2008 | 05:34 PM
BORICAN's Avatar
Default klunking noise when turning?
Is this noise common or is it the stabiliser or ***** joints? Anyone know?
Also wheels feel like they are loose and sliding a bit.
Old Dec 1, 2008 | 05:42 PM
70GT6's Avatar
Default Re: klunking noise when turning?
How many miles?
if lower miles -more likely requires a wheel bearing to be tightened or the steering box adjusted.
Old Dec 1, 2008 | 05:58 PM
BORICAN's Avatar
Originally Posted by 70GT6
How many miles?
I just hit 53,000
Old Dec 2, 2008 | 04:17 AM
spensley's Avatar
Check out the threads on replacing the steering stabilizer - I think some people there report changing their stabilizer ended the clunking.
Here's one thread - there may be more...
https://www.crossfireforum.org/forum...ing+stabilizer
Old Dec 2, 2008 | 05:59 AM
Stogey's Avatar
Hey Angel ! Missin the weather in Texas yet ???
Old Dec 2, 2008 | 04:09 PM
BORICAN's Avatar
Hell yeah! It's so cold i can't even ride my bike. Friday my car wouldn't start because the Starter was frozen. This place Sucks.
Old Dec 2, 2008 | 04:10 PM
BORICAN's Avatar
Thanks Spensley. I went on and ordered it. I will replace it and hopefully that will be it. Thanks
Old Dec 21, 2008 | 01:01 PM
breezytrees's Avatar
Any updates. Did it solve the issue? I have the same problem when turning, but mine only occurs at really low speeds on bumpy surfaces.
Old Dec 21, 2008 | 05:06 PM
BORICAN's Avatar
Mine only does it at real slow speeds. I will do it tomorrow. I had to take a safety class in order to use the auto shop on post. The stabilizer got here thursday so I will do it tomorrow when I get off work. Hopefully it works. I will let you know tomorrow if all goes well and i get to put it on.
Old Dec 22, 2008 | 10:05 AM
BORICAN's Avatar
Just replace stabilizer and the klunking stopped. Steering is stiffer but I would like it a little more stiffer. any suggestions what else might need replacing?
Old Jan 22, 2009 | 11:26 AM
1x100's Avatar
I just returned from dropping my car off at dealer. Same problem in addition to a loud clunking noise coming from right rear tire area. Sounded like something was "loose" and rolling around in the trunk!
Hope I've done the right thing; but with no mechanic ability, nor anyone I know who can assist, dealer is my only option.
Pray for me!
Old Jan 22, 2009 | 09:45 PM
smokey847's Avatar
Pray for me!
I'm having the same issue. Could anyone be a little more specific on the klunking? Is it kind of like a thrashing almost? And there is a little bit of play in the steering?
Old Mar 12, 2009 | 01:33 PM
BORICAN's Avatar
Default Make Sure You Check The Bearings!
I had the same Thrashing. I thought it was my stabilizer too. i replaced that. Come to find out the bearings were going bad. I was headed to work yesterday and tire almost came off. Now I have to replace inner/outer bearings, Spindle and Hub.
Make sure you get the bearings checked before it's too late. It's costing me $1,228 because the Warranty people said it was caused by the bearing failure which is wear and tear, which they don't pay for. "So make sure you check the bearings!"
ty_ty37
Jun 27, 2024 10:42 AM
Valk
Jul 12, 2021 09:49 PM
Sterling57
Apr 11, 2016 06:11 PM
2005 Ragtop
Oct 3, 2015 03:01 PM
Oct 1, 2015 01:42 AM
