Stern ST-1's on an Alabaster, help/opinions please? :)
Old Jan 20, 2009 | 08:00 AM
maxcichon's Avatar
Default Re: Stern ST-1's on an Alabaster, help/opinions please? :)
Originally Posted by xfirecoupe
Ok, that definetly gives me something to go off of. I'll probably order those spacers as soon as my order for the rims go through. Not having to find color specific bolts is great too. If you were doing it all over again, were there lug bolts that you could have bought that you wouldnt have had to grind 2mm off of AND not worry about your e-brake springs AND work with the Stern ST1's, or is this gonna be trial and error on the bolts?
If you are going with ST1's and 10 mm and 15 mm spacers, I'll go home tonight and measure the length of the taper seat lugs I ordered and ended up with. I'll let you know tonight.
Old Jan 20, 2009 | 08:51 AM
Steve Hellums's Avatar
You will also want to make sure you are getting the correct type of lug bolt. The OEM bolt's are ball seat, the Stern's I have are conical. I'm not trying to tell you what to do, but what I did was get the wheels & spacer's that I wanted, put the spacer on the wheel, used an OEM bolt to stick through them both together to get a measurement of how long of a bolt I needed to thread into the hub 16mm. 16mm is how far the OEM's thread into the hub.
Well, he asked for opinions, I wasn't looking to ruin anyone's day. I think chrome is cool on cars that are made of metal. Then again, I would prefer the huge grilles on some of the oldies to be flat black. The whole 30" wheel craze ruined chrome for me. Plus, chromed engine parts such as alternators fail because the chrome doesn't allow heat to escape. There is alot I don't like about it... but I do have to say I love black chrome, but its expensive and nobody in NY does it (or chroming for that matter).
PS: fritz, those wheels have a nice shape, but I don't like the chrome. You paid for them though, and you seem satisfied. thats all that counts.
You didn't ruin my day, everybody has different taste in what they like, I was worried when I bought the wheel's that they would like RICE. But I ended up really liking them and get a lot of compliments on them & the car.
Old Jan 21, 2009 | 04:04 PM
07bluezx14's Avatar
My wheels look exactly like those except for the center cap. I had 265/35/18's, on the 18x10's I had on the front of my cobra, fit on the wheel was perfect. 245's look narrow on a 10" wheel. Than again some dumbass put 215's on the front of my crossfire. It clearly says to use 225's on the front. I thinking 235's should fit much better. There is approx. 1/4" of wheel sticking out of the tires I have already nicked one on something. chris
sorry, The 265's were on 9 inch rims, and I had 295's on the 10" out back
Originally Posted by Steve Hellums
I guess I like CHEESE !
New Wheels & Tire's On SRT 6-p1010825.jpgNew Wheels & Tire's On SRT 6-p1010827.jpg
xfirecoupe, you will end up having to use spacers on front with Stern wheels to get the center cap to snap in, I used 10mm hub centrical spacers.
Old Jan 21, 2009 | 05:27 PM
maxcichon's Avatar
I measured 40 mm in front and 45 mm (shortened to 43 mm) in the rear.
Hope this helps.
Old Jan 21, 2009 | 07:03 PM
BuffNSoFly's Avatar
http://www.hmsmotorsport.com/store/s...hardware/studs
I found this site has both 40mm and 43mm taper seat wheel bolts. That way you won't have to grind the ones for the rear.
Correct me If I'm wrong about these being the proper lugs.
Scroll down to the bottom of the page.
Old Feb 23, 2009 | 04:51 AM
BuffNSoFly's Avatar
Bump..!..!...
Was the link I posted the correct bolts?
Old Feb 23, 2009 | 11:00 AM
maxcichon's Avatar
Originally Posted by BuffNSoFly
Bump..!..!...
When I read the description it refered to the length as measured from the "top of the taper". That is not how I made my measurements.
Mine were the length of the threaded section only.
Old Feb 24, 2009 | 07:11 AM
xfirecoupe's Avatar
I ordered the bolts from there. They were an extra 22 or so after having bolts shipped form two different places, but I don't have to do any grinding and they look like they will work correctly. Won't know til spring when I actually get the car out and do some work.
Old Mar 19, 2009 | 09:25 AM
BuffNSoFly's Avatar
I think I got it right this time if anyone else needed help finding these...they have 40mm also.
Check it out...!
http://cgi.ebay.com/ebaymotors/Wheel...Q5fAccessories
psuperti
Feb 24, 2020 10:26 AM
TerryR
Dec 13, 2019 03:27 PM
Robertwav1
Aug 11, 2015 12:08 PM
RED DOG
Jul 22, 2015 08:55 AM
pioneer4x4
Jul 21, 2015 02:13 PM
