C32 Brake upgrade
on
Re: C32 Brake upgrade
Originally Posted by Tazz
Does anyone know for sure if these calipers will clear the storck NA Xfire wheels? It's not just a matter of diameter -- the usual clearance problem is from the inner face of the spokes to the caliper -- I don't like running spacers on the track !!!!
I say just order those Chinese plastic caliper covers, that will turn the stock units into 4 piston AMG brakes in 10 minutes. god I love the cheap manufactuering skills of the asian countries, lol
you know the down side of the AMG calipers will be reduced stopping distance.
on
on
Well I have been checking Ebay everyday and found a deal I couldn't pass up. A complete set of calipers and rotors for $99.00 plus $49 shipping. The parts are used, so I will detail them up paint them and do what ever I have to do to make them look show quality. I will document the install for those who are interested. The set up I just bought came off a CL500, but uses the same rotors and calipers as the C32. Here is the link to what I bought:
http://cgi.ebay.com/ebaymotors/ws/eB...m=200318039437
on
on
Originally Posted by MikeR
What size are the rotors? I like the newer style but that is a heck of a deal... I have pretty new slotted rotors and it would be nice if we could just get the 4 pot brakes to slip on....
MikeR
MikeR
on
on
on
My Ebay calipers just arrived! These came off a 2000 CL500 which uses 330mm (13") rotors. I only paid $99 plus shipping ($145 total) so couldn't resist. The C32 uses the same basic rotors except for they are 345mm rotors (13.5"). These OEM CL500 rotor are in great shape and are factory drilled. They have too much offset, so I will clean them up and put them on the Dallas Craigs list. The Brembo calipers are factory black and in very good shape. They even have good pads and the complete sensor harness on them. I will take before, after and during pictures of the project. I intend to bead blast them to new condition and then paint them MB silver and re-apply the Mercedes Benz or AMG lettering. For rotors I am going to use SRT/SLK32 rotors which are 13"/330mm and the same diameter and thickness as the CL500 rotors that the calipers are designed to fit. This could end up being a very inexpensive big brake kit with a factory OEM look.
Nice...cant wait to see them!
on
I wanted to point out to anyone looking to change calipers, that it is important to match the piston area to the OEM caliper if you want to maintain proper brake balance. The stock n/a caliper has a single 2.25" piston which has an area of 3.96 sq. inches. The OEM 4 piston Brembo calipers I have, have a total area of 3.66 sq inches which is close enough to not make a difference. To find the area of a fixed four pistion caliper you only measure the area of one side of the caliper. The Brembo's have a 1.44" and a 1.62" pistons on each side. Using just one side you come to 3.66 square inches.
Next I am going to tiral fit a caliper to the car and if all looks good will start shopping for rotors and I will bead blast the calipers and paint silver and then either put "AMG" or "Mercedes Benz" on the side. the other option is to leave black or paint red and put the "Brembo" lettering on them. Thougts? I am leaning silver as that goes with all the silver trim on my SSB Coupe.
That is funny
on
Originally Posted by BlueStorm
check the Car and driver specs of the srt6 vs Limited. limited stops in shorter distance. Limited rotors are lighter and have less mass to overcome. those big AMG rotors would take forever to slow down... all your gaining is heat retension with the larger brakes. And I don't see you Auto-crossing the V8 Crossfire in the future.your better suited to building up a TT v6 if that's the goal.
C32 brakes FS …http://www.mbworld.org/forums/suspen...mg-brakes.html
They’re not mine; can’t vouch for the member.
on
on
Project Update:
Today I jacked the car and removed the stock caliper. the CL500 Brembo Caliper bolted right on! They even clear the stock dust shield just fine although I suspect I will have to ditch them when I get new rotors since the new rotors are thicker. I then popped in the pads and verified that these rotors are in fact designed to work with 330mm rotors (SRT-6/SLK32). Next I mounted my wheel up and verified that the wheel clears the calipers. they do clear but it is much closer than stock. See pictures. Now I need to find some SRT rotors. the OEM rotors are very resonable but I am also looking at drilled and/or slotted.
P.S. Someone really should by the C32 brakes that Splinter provided a link to.
on
