C32 AMG brakes installed
on
Re: C32AMG brakes installed
Rears are no big deal, bolt on. Not a big difference in normal braking, but on the track if you're "trail braking" the extra rear braking gives better balance.
You really should try the EBC "red stuff" pads -- even better bite, and great modulation. Low dust too.....
Do you think $750us shipped to Canada is a good deal for a complete set of front and rear calipers with brackets? I have located some and have them on hold but want to make sure i am paying a fair price...
Oh and just to confirm, calipers for a 2003 C32 AMG will fit the bill right?
I'm not sure what you refer to as "brackets" -- the C32AMG calipers bolt directly in where the stock Xfire brakes attach, without any extra brackets.
Rotors are expensive -- look 'em up before you commit !!! I paid just a bit more than that including the rotors and pads......
Also, remember the stock Xfire wheels may not clear the front calipers without spacers.
If you have a pic of these parts, you might want to send it to me so I can confirm they look right. The part about the brackets concerns me, as on the C32AMG the calipers bolt on without any brackets, on both front and rear.
If they are the Brembo front calipers, the Xfire mounting bolts should work. But for the rear calipers, you need the longer bolts as used on the C32AMB. Make sure you clean everything and use Loktite blue and torque to the proper values -- you don't want these babies coming loose!!! Oh, the rear bolts are 16mm (which a lot of socket or wrench sets don't include for some reason).
What rotors are you getting? Don't forget the rear rotors incorporate the drums for the parking brake.
on
Re: C32 AMG brakes installed
Here are some pic's I grabbed elsewhere -- gives you a rough idea of what the calipers should look like. C32AMG are usually silver, but may have been painted other colors. Hope this helps.....
If you get them, remember to mount them with the bleeder screws up (the air bubbles rise, and that's what you want to bleed off.....sounds stupid, but I've seen so many mounted bleeder screws down...)
on
on
I still have a full set of used SRT6 rotors sitting in the garage that are looking for a home. Lots of miles left on them. I upgraded at about 23K miles. If anyone goes with the CL500/SL500 calipers (or anything else that uses the 330mm rotor) they would work with the SRT6 rotors.
on
your preaching to choir!! i did exactly that mounted the carriers and calipers backwards and spent 2 days trying to bleed the suckers!!! it was waldig who asked, were are the bleeders pointing? 30 min later BRAKES!!!
Tazz, Looks really good. Did you have to use spacers? I didn't have to with my wheels which are similar spoke pattern, but my front wheels are 8 inch wide instead of 7.5"
on
Originally Posted by Tazz
Yes, used 5mm on the front to clear the calipers. Sorry, I just cannot bring myself to grind down the outside of the calipers and then trust my a*s to them at the end of the straight at 220kph!!
New pic --- went with the SRT-6 wheels for the better X-factor, can go with 5mm spacers in the front and clear the big brakes. They're lighter too.....but a ***** to clean!
I see you got them installed..! They look great...I'm going to miss those wheels .
Hopefully everything got delivered Okie Dokie.
