Need Different Tire Size-Rubbing
Old Jun 12, 2009 | 08:25 PM
Marine05's Avatar
Unhappy Need Different Tire Size-Rubbing
Hello My Friends,
Well my never ending story. Camber was out of whack because previous owner lowered car. He also had changed the OEM tire size in the rear.
I had the K-MAC Camber Kit installed in the front which brought the camber within spec, but now that it is aligned, the tires rub against the wheel well when I turn. The alignment guy said a lower profile tire will help. I currently have 225X40X18 in the front (OEM Spec) and 275x35x18 in the rear. Here are my questions:
1) Can I lower the profile of the front tires without messing up the handling/breaking?
2) If so, what are the next 2 lower profiles I can use given the rear tire sizes?
Thanks,
Glenn
Old Jun 13, 2009 | 07:10 AM
dwightdmagee's Avatar
Banned
Default Re: Need Different Tire Size-Rubbing
Originally Posted by Marine05
Hello My Friends,
Thanks,
Glenn
Both tires you mention are fine. The front OEM IS 225/40R18, and I believe you meant to say that the rear is 275/35R19.
You may want to try forcing the front fender well back a little bit. Either that or your camber is still screwed up; they shouldn't be rubbing.
If you want to consider other tires, you can stay with the same sizes, but look into some that have a more 'rounded' tread profile. Some, like the Conti's have a very 'squared' tread-to-sidewall, which is probably the exact point that is rubbing your fender well. You can tell a 'rounded' tread pattern tire by looking at the specs; it will show a tread width that is somewhat less than the section width.
If you chose to try a lower profile tire, I'd suggest dropping the aspect ratio on both front AND rear tires - just to maintain the relationship. Have a look at 245/35R18 up front and 275/30R19 in the back. This is a nice low-profile staggered combination. They are both shorter but a bit wider than OEM.
Good luck.
Old Jun 13, 2009 | 08:21 AM
Marine05's Avatar
Thanks. The car was lowered with Eibach springs and it is pretty low. The rear wheels BTW are 18 inches. By forcing the wheel well out a bit, do I simply hammer it or is there a better method? I will also check into a more rounded bead on the new tires. Great advice!
Thanks again,
Glenn
Old Jun 13, 2009 | 11:28 AM
Banned
How to 'adjust' the wheel well? Gosh, I don't know. I guess take the wheel/tire off and persuade it with a small maul. Pop the hood and see what's behind it first, but can't imagine there's anything that could be hurt.
Let 'er rip.
TerryR
Dec 13, 2019 03:27 PM
Jonacross
20
Jul 17, 2017 11:19 PM
Mackel
Sep 29, 2015 02:41 PM
SRT6_Roadster
Sep 24, 2015 04:40 AM
stelrz1
Sep 21, 2015 11:18 AM
