Tirefit Procedure?
Old Nov 10, 2009 | 05:49 PM
Darticus's Avatar
Default Tirefit Procedure?
Did anyone try this fixing method? Does it work or is there a better procedure in tire fixing in winter or summer??? Thanks Ron
Old Nov 10, 2009 | 06:16 PM
AlanH's Avatar
Default Re: Tirefit Procedure?
Which method? Forget a link or something?
Old Nov 10, 2009 | 06:31 PM
Darticus's Avatar
Tirefit is the method in the manual for fixing a flat. It uses the fixing things that come with the car. Ron
Old Nov 10, 2009 | 06:40 PM
AlanH's Avatar
D'oh! Nope, haven't had it long enough to have a flat, but have been advised that I should make AAA my friend.
Old Nov 10, 2009 | 06:42 PM
Darticus's Avatar
How long do you have yours? I have mine about 3 weeks. Ron
Old Nov 10, 2009 | 06:45 PM
never had a flat yet, but AAA should be a have too.....
Old Nov 10, 2009 | 06:46 PM
Beaner's Avatar
If I get a flat do to a nail or some type of puncture like that I just pull it out, put a plug in it, pump up the tire and drive to a tire repair shop when it is convienent to do so. Here is a link to give you an idea
How to Use a Tire Plug Kit
Old Nov 10, 2009 | 09:26 PM
Avoid using that black gooey crap (tirefit) that came with our cars.
It will mess up your TPS and most likely trash the inside of your tire.
Carry a pair of needle nose pliers and a good tire plug kit.
If you need to do a roadside repair this is the way to go.
Then use the supplied air pump to fill the tire back up with air.
Old Nov 10, 2009 | 10:10 PM
AlanH's Avatar
Just made the scond payment
2006 Base coupe/Black/6 Speed 18,000 miles +/-
All that stuff is under the mat in the hatch, still in the pastic wrap, and after reading Valk's post, I'll take his advice. I happen to have a good tire plug kit, and have used it on other vehicles over the years
Old Nov 11, 2009 | 10:25 AM
MikeR's Avatar
I keep a tire plug kit in each car... no goo for my tires...
syfi
Mar 28, 2026 04:14 PM
needfreetime
Aug 9, 2024 09:28 AM
ZERACER
Jul 7, 2020 10:21 PM
Rob M
25
Nov 5, 2015 05:23 AM
toob
Sep 26, 2015 11:44 AM
