rough braking and loud squeal with rotex golds
Old Nov 13, 2009 | 11:05 AM
white04XF's Avatar
Default rough braking and loud squeal with rotex golds
finally got my front brakes on today after getting the correct rotors in. first drive, the fronts feel like they are grabbing way too much and the rears are still squealing, those of you who followed me at the dragon know what I'm talking about. anyone have any ideas?
Old Nov 15, 2009 | 12:55 PM
Infinite's Avatar
Default Re: rough braking and loud squeal with rotex golds
they are a race pad, rough braking and squealing are normal. The pads are metallic, not organic. Get used to it or get new pads.
Old Nov 15, 2009 | 04:32 PM
danimal's Avatar
Not true at all.
white04XF, what rotors did you get? As far as the rotex pads, did you use anti-squeal on the back of the pads and did you do a proper bedding-in of the pads?
I have had rotex pads on mine for over 32K and have never had the first squeal or grabbing brakes. They are just as good, if not a little better, than the factory pads without the dust.
I would recommend taking them out, using the anti-squeal as directed, and then bed them in using whatever method you feel comfortable doing. A google search will give you any number of methods to bed your pads. It works.
Old Nov 16, 2009 | 09:41 AM
white04XF's Avatar
discovered that the right front rotor was warped, that is what was causing the rough braking. I'm going to put some stop squeal on them when I get a chance, the guy that did the work looked at me like a dumbass.
Old Dec 15, 2009 | 12:57 AM
KJN's Avatar
KJN
Default help with grabbing rotex gold brake pads
Hi,
I too feel like the new front brakes (rotex gold) are grabbing as well..What is the problem..is it a brake problem or installation issue..I had the Chrysler Crosssfire tech put them in..can he adjust them? I only have a 1000 miles maybe less on the pads. I was hoping they would soften up..
KJN
Old Dec 16, 2009 | 02:04 PM
Stogey's Avatar
Default Re: help with grabbing rotex gold brake pads
Originally Posted by KJN
Hi,
KJN
Did he surface the rotors before installing the new pads ? Did he clean and lube the calipers where the pads ride ? Did he burn in the new pads ?
There is no brake adjustment except on the parking brakes.
Valk
Jun 22, 2025 09:15 PM
RamblinShamblin
Aug 12, 2017 10:55 PM
8ighth Wonder
Dec 15, 2015 01:42 PM
crossfireusa
Oct 28, 2015 12:03 AM
brandoni
Sep 30, 2015 07:48 PM
