37 lbs of Fury!!!
Get you some really long bolts and run them both at the same time..... You could have the first SLK dually dragster. LOL
Originally Posted by 32krazy!
i dont know what to do with my regular set while im racing. cant just leave my oz's laying around! the closest track to me is almost 2 hrs away.
yeah i dont see either of those as viable options. maybe bmorgan will let me sleep in the garage and race at his track!
dually slk32? hhmmmm.... well i cant have a dual exhaust maybe this could work!!
Originally Posted by bmorgan
Hey Steve.... You have an open invitation anytime you want to come down this way. Got an extra bed with your name on it. Sheets and pillows cost extra!
The track opens back up the 31st of this month.
Just take your OEM wheel and lugbolt(both OFF the car) and put the lugbolt in it and measure the "stick out" on the backside. I know it's supposed to thread in 6 threads.....for the rear wheels to not hit the e-brake.
Hoosier DRs are DOT rated..........but not for highway use. I drive on mine to/from the track 20 miles each way with no issues though. It's just a matter of how much faster you will wear them out.
As far as the whole "what to do with my street rims" deal goes.............you can just put them inside your car with you. You will run slower times but you won't have to worry about someone stealing your rubber for the ride home.
cant keep them in the car. doesnt make sense to have 74 lbs of race wheels and then add another 100 lbs in the trunk!
i may end up doing the trailer thing. not sure i want that either. damn i wish i had a track close!!
i was looking at the hoosier site and they say the smallest rim for the 255/50-16 is 8". whats the risk with the 7" rims?
The tires are fine on a 7'' rim...............I already have them on a 7'' rim and so do many other people. I would however advise you to NOT go whipping around tight corners at high rates of speed.
did you get the r6 or the a6 tires? i looked at the tirerack website but dont really see much difference in the tires. also do you recommend the heat cycle they advertise? definatly want my moneys worth as the tires cost a pretty penny!
HA! not much chance of that! these are my stright line wheels only. i have dunlop direzza sports for the twistys.
Moparburst, I know that you did a lot of research on this, and I appreciate your sharing with us. I purchased a set of the CLK rims like yours. I will be looking into tires for them this week. So, I basically have 2 options that I am considering. The Hoosiers, and the MT ET Street DRs. I have 27 miles each way to the track, so just a little more than you. The Hoosiers are 22 lbs., and the MT ETs are 29 lbs. The weight difference alone has me considering the Hoosiers. The street-ability has me leaning towards the MTs.
Other than the obvious weight savings, were there any other factors that made you decide to go with the Hoosiers over the MTs?
Thanks, Bob
Thanks, Bob
umpqua rafter
Aug 24, 2015 09:06 AM
