225/35/20 or 225/30/20??
Old Mar 15, 2010 | 12:18 AM
samer2thamer's Avatar
Default 225/35/20 or 225/30/20??
does anyone have 225/320 setup up on their front wheels with any issues? my local tire shop told me it wouldnt fit, so im stuck with 225/30/20 but the ride is way too rough for me
Old Mar 15, 2010 | 10:01 AM
32krazy!'s Avatar
Default Re: 225/35/20 or 225/30/20??
i doubt if 5mm sidewall height is going to make much ride diff. could be 20's on the front or the suspension setup you are running
Old Mar 16, 2010 | 02:42 AM
ya i have the stock suspension, with the 20's all around. I took it to another tire shop and asked them if they could try to see if they would fit and they do BUT they are rubbing in the front. and the ride is amazingly better, a lot more smooth now that i put the 225/35/20's on there instead
Old Mar 16, 2010 | 08:44 AM
32krazy!'s Avatar
better watch that rubbing. sidewall blowouts on the front at speeds can be disaterous!
Old Mar 16, 2010 | 01:36 PM
So let me get this straight, you had a 225/30-20 on the front and there were no issues? And now with 225/35-20s there is minimal rubbing??
I only ask because I am running 225/30-20 up front and with my backspace/offset and a stock suspension, I have to use 10mm spacers in the front to keep from rubbing.
I would be very interested to see a picture of the wheels and how they look in relation to the wheel well, also, a picture from behind the wheel to see how close it is to the bottom suspension nut.
Old Mar 20, 2010 | 09:16 PM
yea but i actually took care of the rubbing my self, I just cut some rubber on the wheel well where it was rubbing and now its very good ride with no rubbing...
btw I dont have any spacers..
as soon as i get a chance i will get you a pic
kolevski
17
Oct 20, 2009 11:37 AM
CrossfireMan1999
Jun 20, 2009 11:09 AM
Knghtrdrzn
Dec 24, 2008 02:05 AM
Extensive
Apr 15, 2007 02:08 AM
