TVT Design Adjustable Rear Toe Arms!!!
Old Mar 17, 2010 | 03:25 PM
TVT_DESIGN
Guest
Posts: n/a
Default TVT Design Adjustable Rear Toe Arms!!!
Our Adjustable Camber arms sold so well we are having trouble stocking them. So the next thing we are looking to offer is the adjustable toe arm.
This is the lower arm closest to the front of the car. It has been brought to our attention that some customers are running so low, or track set ups, that the camber arms are not enough!
These are made of high quality aluminum with Red anodized ends. These are a perfect replacement for stock for both the track and street guys/gals.
Attached are some pics.
We will be releasing sway bar links and the final 2 adjustable bars for a fully adjustable suspension, but until then enjoiy these.
Old Mar 17, 2010 | 10:02 PM
TVT_DESIGN
Guest
Posts: n/a
Default Re: TVT Design Adjustable Rear Toe Arms!!!
Rear Toe-in/Toe-out
Toe-inToe-in at the rear make's your car more sticky at the back and easier to drive This may stabilize your car. But be careful, this is a very sensitive adjustment.
0˚– -3.5˚
Toe-outRear Toe-out makes the rear of your car very instable. This adjustment is never used.
+1˚
Neutral-ToeFor a neutral feeling adjust less toe-in. The car will be slightly faster and more efficient. But the car may stick less in the back and that could cause slower laptimes.
0˚
Pulled from the net.
Old Mar 18, 2010 | 08:12 AM
ImportLabSRT's Avatar
When you get get a complete package together let me know Anthony. I will be the first one on the list to buy it
Old Mar 18, 2010 | 01:17 PM
Infinite's Avatar
same
msglngth
Old Mar 18, 2010 | 01:43 PM
TVT_DESIGN
Guest
Posts: n/a
Getting all 4 arms complete is more of an issue of suppliers then it is of actually doing the project. I am very adament about keeping business in the states and working with small businesses, so this is kind of causing a dilemma. Can I outsource to China and get them made for half the price? Probably, but I'd rather not.
Old Mar 18, 2010 | 02:09 PM
Infinite's Avatar
I have a local machine shop that can do whatever, we build motorcycle suspension stuff, so turning arms isnt an issue
Old Mar 18, 2010 | 06:03 PM
Well the most important are camber and toe which you have.
Old Mar 19, 2010 | 05:00 PM
TVT_DESIGN
Guest
Posts: n/a
We mocked up the final arm today and attached some pics.
All together we have 3 adjustable arms and are looking into making the adjustable ball joint in the rear if necessary.
maxcichon
Apr 21, 2021 08:29 AM
xfireohio
Jul 20, 2020 12:03 AM
velociabstract
28
Oct 28, 2015 12:46 PM
Bayukbros
Jul 29, 2015 10:16 AM
Jerrysrt6
Jul 24, 2015 09:15 PM
