What kind of lug bolt is THIS?
Old Jan 29, 2011 | 05:35 PM
Default What kind of lug bolt is THIS?
I was, for the first time, washing the Graphite car today. I took the wheel bolt covers off to find a FILTHY MESS and one other thing - every wheel has one of these oddball bolts in it.
What is it? Some kind of antitheft device?
I want them OFF the car ASAP - can we still get lug bolts?
Old Jan 29, 2011 | 05:42 PM
Larry Hitze's Avatar
Default Re: What kind of lug bolt is THIS?
Pizza, Those are locking lug bolts, You will need the coresponding key to get it off easily. I don't know how to get it off without the key easily. Look around in the car everywhere for it. Larry
Old Jan 29, 2011 | 06:06 PM
old man's Avatar
looks like a McGard lock
Old Jan 29, 2011 | 06:30 PM
dgspikes's Avatar
wheel locks, hopefully the previous owner put the "key" and the old lug nuts somewhere in your car. It should look like a socket, without it getting those locks off will be tough. The only people who can do it with little or no damage is the guy who was going to steal your rims.
Old Jan 29, 2011 | 07:09 PM
SparkieSRT6's Avatar
SSB SRT6 405hp/401Tq
If you can't find it hidden in the car or get it from the previous owner, most large tire shops have the various keys. (hopefully)
Old Jan 29, 2011 | 07:59 PM
That was the response I was looking for.
THANKS!
Pizzaguy
(Haven't actually LOOKED for it, might be in one of the pockets in the trunk.)
Old Jan 29, 2011 | 08:31 PM
if you don't find the key,, find a socket that is just slightky too small to fit over it ,,,put the socket on a braker bar( the reason you want the socket on the B B is because you will make the socket loose over the lock tring to put the B B onto the socket ) now HAMMER the socket on to the lock at the same time every time you try to turn it off make sure you hit the end of the breaker bar ... within 4 to 5 hits ,or 20 to 25 hits of the B B it will come loose, then u can replace it wit another lock,,,or a lug bolt. jim
Old Jan 30, 2011 | 06:12 AM
I support the above comments. Take the car to a Discount Tire shop, where they only do tire installs. Pep Boys is another possibility since they handle the McGard product line. They should be able to get the McGard lock off.
Good Luck,
Old Jan 30, 2011 | 06:16 AM
I've actually got the Crossfire version of the locking lug bolts on my coupes wheels. The spare lug bolts & lock socket are in the console.
Old Jan 30, 2011 | 06:31 AM
...can we still get lug bolts?
Here are some links where you can get Crossfire lug bolts:
XFire Chrome Lug Bolts
eBay Chrome Tuner (Splined) Lug Bolts for XFire
Here's an example of what's probably on your Roadster.
McGard Wheel Lock Lug Bolts
Here's the Mopar set I have on my coupe: Mopar XFire Wheel Lock Set
Old Jan 30, 2011 | 08:24 AM
Thirteendog's Avatar
AMX this is Mark we're talking too. We don't want him using a hammer around those wheels
Old Jan 30, 2011 | 09:06 AM
we remove them that way every day haven't messed up a wheel yet ,,in fact my car had locks on it when i got it 3 years ago and i took them off that way,, if u take them to a shop that is the way they will do it ,ofcourse they will or should look to see if they can find a key, no key then hammer, that is just the way it is in every shop. good luck.hope you find a key makes it so much easier. jim
Old Jan 30, 2011 | 11:04 AM
bmorgan's Avatar
My first thought was....... Mark has led too sheltered of a life if he does not know what a locking lug looks like. Just razzin' Mark.... Luv ya man.
Old Jan 30, 2011 | 11:10 AM
I had a set of those lugs on a former Camaro with custom wheels. They saved my wheels from getting stolen one night. The thieves took all the lugs but the McGards. I thought I had dropped the transmission when I started to drive unknowing I only had one lug securing each wheel.
Old Feb 2, 2011 | 12:21 PM
Ok, the shop I got my Red car's tires from has the "Key" or socket, so - anyone have four OEM bolts I can have or buy or trade?
Thanks, Dedwards, for post 10 - I'd really like to just get four of the OEM bolts.
Old Feb 2, 2011 | 05:07 PM
bmorgan's Avatar
Mark, if you don't mind coming down to Warner Robins, I have some I can give you. PM me if you are interested.
Old Feb 2, 2011 | 05:59 PM
For those interested in a source for German-origin lug bolts for the Crossfire, here's a link:
RAD German Lug Bolts for XFire
Old Feb 2, 2011 | 06:49 PM
bmorgan's Avatar
Those have a 23MM shank, which is too short for the Crossfire. I believe the Crossfire OEM length is 40MM. ezaccessory.com usually has the best prices on lug bolts. Here is a link to some that should work. Wheel Adapters|Lug Nuts|Wheel Spacers
Old Feb 2, 2011 | 08:56 PM
MikeR's Avatar
I got my new lug bolts to go with spacers from them....they have all sizes available.... excellent quality
edit: yes, factory bolts are 40mm...
Old Feb 2, 2011 | 09:06 PM
THANKS!
Pizzaguy
No sane person would take the key out of the car.
So this could be a big test for you Mark if you find that key.
