tire sizes to fit your car
  #61 (permalink)
Old 02-20-2023, 06:48 PM
Default Re: tire sizes to fit your car
Originally Posted by Padgett
Having a spare set of wheels and having lost much of my gluteus maximus am thinking 235/40r18s all around might be a softer idea. Near $100 less expensive also. Is 25.4" diameter and a 235/45r18 is 26.4". Of course feeling like the seat bottom foam is thoroughly ex does not help. Comments ?
235/40-18 is 9.3 tread on the ground and 25.4 tall and will work on front with the stock rim 235/45-18 is also 9.3
255/40-18 is 10" of tread on the ground and is 26 tall maybe this will help
  #62 (permalink)
Old 02-20-2023, 07:24 PM
Padgett's Avatar
Thank you but front 18s are 7.5s and most 235s want an 8" rim. Am now thinking 225/45r18. 4" sidewall and almost exactly 26" tall. Is a 26" diameter ok in front ?
  #63 (permalink)
Old 02-20-2023, 08:18 PM
Padgett's Avatar
If 26" is too much in front then 215/45r18 looks like the answer for softest ride. What is the diameter limit in front please ? Have to remember the coupe is only 3100 lbs. Suspect would be better on 17s or 16s but need to go with what wheelz are here.
  #64 (permalink)
Old 02-20-2023, 08:45 PM
Buy two used 26" tall put them on the car, if they do not rub then when they wear out replace with 26 tall for front and rear.
  #65 (permalink)
Old 02-20-2023, 08:54 PM
Padgett's Avatar
Thank you and a few decades ago would have done that but have little energy these days and if unknown whether the 225/45r18s will fit then 215/45r18 it is.
  #66 (permalink)
Old 02-21-2023, 12:36 AM
u got it that is the best for the front and rear then u can rotate when needed
  #67 (permalink)
Old 02-21-2023, 10:35 AM
Padgett's Avatar
Then a 26" tire is too big for the front ?
  #68 (permalink)
Old 02-21-2023, 11:44 AM
Padgett's Avatar
This is like a lawyer's convention, impossible to get a simple "yes" or "no". Is a 26" diameter tire too big for the front on a stock 18x7.5" rim ? Nobunny nose ? YWTK
  #69 (permalink)
Old 02-21-2023, 01:29 PM
by the book ,yes but on some crossfires they run 26 on the front and it is fine,also as i said the tire manufacture say their tire is 26" tall but it is not it is 25.9
  #70 (permalink)
Old 02-21-2023, 04:43 PM
Padgett's Avatar
Are you saying a 25.9" BFG Comp-2 in 225x45r18 (Tirerack) will fit on the front of an '04 Coupe on a 18x7.5" stock front rim ? yes/no is fine. YWTK
  #71 (permalink)
Old 02-21-2023, 05:33 PM
No.
a 245/40-18 will fit 9.6 tread width, 3.9 rim to ground ,,25.7 tall will fit
now the BFG are true to size but a Fullway hp 108 both 225/45-18 the BFG is 26 tall where the Fullway is 25.95 tall that is what i have been trying to tell you, manufacturer are not all the same example you do know is drag radials 255/45-17 crossfire size M&H is 10 wide 26 tall,,where Hoosers are 10.1 wide and 25.9 tall look here
Tire Size:
Michelin Pilot Sport
255/45-17
Tire Construction:
Radial
Sidewall Style:
Blackwall
UTQG Tread Wear Rating:
320
Tire Diameter:
26.10 in.-------------
Section Width:
10.00 in----------
Tire Size: nitto 255/45-17
Tire Construction:
Radial
Sidewall Style:
Blackwall
320
Tire Diameter:
26.06 in.---------
Section Width:
10.04-----------
  #72 (permalink)
Old 02-21-2023, 06:11 PM
Padgett's Avatar
Great idea except anything over a 225 calls for at least an 8" rim. Has anyone mounted the 245/40-18 on a stock 18x7.5 inch rim ?
Am probably getting too deep into this but research before purchase is cheap and already have the wheels. Do think the 245s would look good.
Thank you.
  #73 (permalink)
Old 02-21-2023, 08:35 PM
I have installed tires on rims that call for the rim to be an inch larger some tires i have used on my crossfires especially the V8's example tires that call for 11" rims ,and i put them on example i ran 335/35-17,, 13.2 wide and 26.2 tall mounted on 9" rim drag radials stop worrying about the width of the rim, as long as u are 1" or so..
  #74 (permalink)
Old 02-22-2023, 12:35 PM
Padgett's Avatar
OK then after all of this dithering am down to 235/40-18 or 245/40-18 on front with stock 18x7.5" wheels.. Any suggestions or comments about which ? Pretty sure the 235 will fit, not so about the 245. Decisions, decisions.
  #75 (permalink)
Old 02-22-2023, 05:51 PM
245/40-18 both front and rear the front rims will work and same rim for the rear 25.7 tall and 9.6 wide on both
  #76 (permalink)
Old 02-22-2023, 07:28 PM
Padgett's Avatar
Great, exactly what I needed to know. Should give softest ride. Thank you.
  #77 (permalink)
Old 02-23-2023, 09:23 AM
any time my friend ,,, when u buy your tires have the shop mount the fronts for a test fit,, they know how to check if it will rub,
this is a 2004 so the suspension may be collapsed a little from all the years of driving that is why you should ask for a test fit. jim
  #78 (permalink)
Old 02-23-2023, 12:21 PM
Padgett's Avatar
Thanks, maybe should stick with 235/40r18, It does ride like a one ox cart.
  #79 (permalink)
Old 07-25-2023, 09:03 PM
I've got a set of wheels and 345/35-18's of my Audi A6 3.0T. Will they fit a 2005 Crossfire?
  #80 (permalink)
Old 07-27-2023, 11:14 AM
no,,, first the hub on the A6 is 57.1 the crossfire is 66.5 so the wheel will not fit onto the hub ,, the a6 tire is 27.5 the crossfire max is 26..9 so the 345/35-18 is 27.5 tall
yes with spacers u can make them fit but not me.
Quick Reply: tire sizes to fit your car
