Lowering a crossfire
Hi there,
I'm sorry for my bad Englisch but i'm from Holland. I have a crossfire, but want to lower it a couple of cm. My last cars were a golf v and audi a4, both with a adjustable springs ans coilovers. The chrysler needs to go a few cm down, i guess 4 or 5. Does anyone got some pictures from a crossifre and can tell how much cm the car can goes to the ground?
Thanks!
Ludo
Thanks!
Ludo
on
Re: Lowering a crossfire
with a spring kit you can get about 3.5cm(1.5") on the Crossfire....you may need to different spring pads/seats to get what you want and no rubbing...depending on if you are using stock wheels/tires or not...
My car has Eibach Pro springs and Koni adjustable shocks with replica AMG 810 wheels 18x8.5 ET35 front with 235/40 tires and 19x9.5 ET35 rears with 285/35 tires.... I have the tallest springs pads in front and back and get a little rubbing in front when going max turn... and a little rubbing in back when I hit sharp bumps at speed... I need to go to a 30 profile in back and I will get back to stock diameter and not rub....
Also note that when lowering, you will likely need to get adjustable camber arms or bolts for the back and bolts for the front.... lowering the Crossfire this much REALLY makes the wheels go negative camber......
on
Yes thats legal (almost everything is legal here)
But I dont like to cut the oem springs.
I think I want to buy this set:
Chrysler Crossfire KW Suspension Verlagingsveren - 25027006 | Stroevemotorsport.nl
on
Read up on this subject before deciding? You will have to get different spring pads and perhaps adjustable rear camber arms to offset the added negative camber lowering produces. And, let us know what you do?
rayth
41
07-31-2019 04:02 PM
victorlautreamont
06-29-2015 01:51 AM
