alignment question
Old Apr 21, 2012 | 10:31 AM
ModlessG's Avatar
Default alignment question
I had an alignment done yesterday.What do the numbers mean??The car is definitely better to drive now
File Type: pdf
Old Apr 21, 2012 | 01:18 PM
MikeR's Avatar
Default Re: alignment question
Did you hit something with the left side of your car??? you are still pretty negative camber in front and back... did they install the MB bolts in front to try and get it in spec? it dosent really look like they did....
the camber is NOT adjustable in front or back without getting the MB bolts or Kmac kits for the front and adjustable camber arms or Kmac kits for the rear...
With your current settings you are going to wear out the insides of your left side tires faster than the right....
Old Apr 21, 2012 | 01:47 PM
maxcichon's Avatar
Quite right, Mike. Or left?
Old Apr 21, 2012 | 02:18 PM
ModlessG's Avatar
I am not aware of hitting any thing the car has never been in an accident. There are some monster pot holes around here though. I just put larger tires on the rear 285/30/19 on the stock rims. Would that throw it off? I found a front camber kit at Needswings but no rear kit. Are these camber bolt kits hard to install??Beastmode has the rear bolt kit. thanks
Old Apr 22, 2012 | 02:27 AM
MikeR's Avatar
Needswings sells the rear adjustable camber arms...look under suspension... MikeR adjustable camber arms...
Changing your tires would not cause your alignment problem....
TerryR
Dec 13, 2019 03:27 PM
jimf
Oct 10, 2015 10:22 AM
2005 Ragtop
Oct 3, 2015 03:01 PM
Charlesl
Sep 30, 2015 10:46 PM
brandoni
Sep 30, 2015 07:48 PM
